caliper bolt torque
Mar 17, 2008 | 06:45 PM
caliper bolt torque
Hi, my truck is a 06 f-350 cc/lb/4x4/drw/psd/4.10's and my hawk pads are due in this wed.
can anyone tell me what the calliper bolt torque is for the front and rear.
Thanks,
Rich
Mar 17, 2008 | 07:50 PM
Looks like 27 lb-ft on the 02 models for the caliper pin bolts.
Mar 17, 2008 | 10:53 PM
Both front and rear caliper bolts on a '06 F-350 DRW should be torqued to 56 lb-ft (76 Nm).
Mar 18, 2008 | 05:05 AM
Hi, thanks for the replys
I should have been clearer sorry,
Caliper mounting bolt torque fr/rr
caliper slide pin bolt torque fr/rr
Thanks Rich.
Mar 18, 2008 | 07:56 AM
I think this should cover just about everything...
Front Brake Torque Specifications...
Brake caliper bolts (F250, F350) - 56 lb-ft (76 Nm)
Brake caliper bolts (F450, F550) - 46 lb-ft (63 Nm)
Brake caliper flow bolt - 35 lb-ft (48 Nm)
Brake caliper anchor plate bolts (F250, F350) - 166 lb-ft (225 Nm)
Brake caliper anchor plate bolts (F450, F550) - 295 lb-ft (400 Nm)
Wheel hub extender nuts - 130 lb-ft (176 Nm)
Brake disc shield screws - 8 lb-ft (11 Nm)
Rear Brake Torque Specifications...
Brake caliper bolts (F-250, F-350 single rear wheel) - 26 lb-ft (35 Nm)
Brake caliper bolts (F-350 dual rear wheel) - 56 lb-ft (76 Nm)
Brake caliper bolts (F-450, F-550 dual rear wheel) - 46 lb-ft (62 Nm)
Brake caliper flow bolt - 26 lb-ft (35 Nm)
Brake caliper support bolts - 101 lb-ft (137 Nm)
Disc-to-hub bolts - 89 lb-ft (121 Nm)
Brake caliper anchor plate bolts (F-450, F-550 dual rear wheel) - 295 lb-ft (400 Nm)
Brake caliper anchor plate bolts (F-350 dual rear wheel) - 203 lb-ft (275 Nm)
Brake caliper anchor plate bolts (F-250, F-350 single rear wheel) - 203 lb-ft (275 Nm)
Mar 18, 2008 | 06:24 PM
Very nice,
ThankYou so much, I'll be busy Saturday.
Rich,
Aug 27, 2019 | 06:00 PM
Glad I ran into this thread. I just pulled the front wheels to check brakes and one of my caliper bolts is missing!
Aug 28, 2019 | 11:04 AM
Quote:
Originally Posted by
Mr. G
Blue Loctite for all brake jobs I do.
Aug 28, 2019 | 03:30 PM
I was wondering about that. I think I will pull them and use a bit of blue.
skid2964
Aug 1, 2023 06:56 PM
MauleOne
1983 - 2012 Ranger & B-Series
Oct 11, 2014 08:38 AM
Tomahawk2506
Jun 3, 2013 10:05 PM
GTOBRIAN
Apr 1, 2013 09:51 AM
osteo16
Feb 16, 2008 12:49 AM
2003 ,
2006 ,
bolt ,
brake ,
caliper ,
calipers ,
f150 ,
f250 ,
f350 ,
ford ,
front ,
ft ,
lbs ,
specifcations ,
torque
