the ccv mod
Old Mar 17, 2008 | 12:10 PM
Superduty krazy's Avatar
Superduty krazy
the ccv mod
Just out of curiosity when doing this mod i have seen guys puting a new pipe between the rubber pipe that connects the air cleaner and the turbo....Just putting this out there it might be dumb, but could i build a new pipe out of black ABS from the turbo to the air filter , coneting them with IC boots or something like that????? any imput will be appreciated
Old Mar 17, 2008 | 12:37 PM
F250_'s Avatar
F250_
Sure, you can do that. Just be aware of pipe inside diameters and be careful to not use a pipe that is more restrictive due to being a smaller inside diameter. Also, I would install a grounding wire from the plastic pipe to the frame to eliminate the potential for static electricity buildup due to the air velocities.
Old Mar 17, 2008 | 12:57 PM
Superduty krazy
Kewl I just wanted anothe opinion before i gave it a go...thx for the reply
Old Mar 17, 2008 | 01:39 PM
superduty4x4's Avatar
superduty4x4
Superduty krazy- save yourself a lot of trouble and just go pick up a 3" ABS coupler- it's 4" OD (the diameter you need) and is basically a direct drop-in replacement for the CCV housing. If you try to build one out of ABS or PVC, you will end up with a smaller diameter (more restrictive) intake tube than if you just use the coupler.
Old Mar 17, 2008 | 02:01 PM
sflem849's Avatar
sflem849
That is what he is trying not to do. He wants to ditch the cobbled together unit that most guys have where you use a pipe for the ccv and a pipe for the filter. IIUC, he is looking to run a piece from the filter to the turbo...nothing in between. Look on eBay, there are a few setups that go part of the way, but not all the way to the turbo IIRC.
Old Mar 17, 2008 | 02:56 PM
superduty4x4
I get that, but if he's planning on using ABS or PVC, he's going to end up with an intake pipe thats 3" ID instead of 4" ID like the OEM setup (at least to the CCV coupler, it reduces at the turbo IIRC). Unless you find an exhaust shop that will custom bend you a piece of 4" tubing for the intake (good luck with that) you're not going to be able to get a 4" tube for the intake.
You are right thought most aftermarket set-ups only run a piece of pipe to the rubber hose connected to the turbo- I've never seen a setup with a single piece of pipe clear to the turbo. This is probably because the intake on the turbo is smaller (3" IIRC) than the filter end- you'd end up with a 2-piece setup anyways.
Old Mar 17, 2008 | 03:14 PM
sflem849's Avatar
sflem849
And they probably can't legally get rid of the ccv...
Old Mar 17, 2008 | 05:16 PM
Superduty krazy
I haven't done anything yet but when i do I will take pics and find out how to put them on here
Old Mar 19, 2008 | 06:13 PM
bad ass diesel's Avatar
bad ass diesel
question on the cv mod??
i have been reading alot on this mod and have a few ??
1)what can i clean the "filter" with? is brake klean ok?
2)i see that most if not all have ran the line out to the back of the truck. why not just right down the firewall and terminate it there like the big rigs? i think that the concern about a low spot for the oil to acc. in and cause a blockage would be eliminated. just a thought thanks
Old Mar 19, 2008 | 06:23 PM
PaysonPSD's Avatar
PaysonPSD
Brake cleaner followed by compressed air, when available, is fine. Submerging and soaking in solvent better, but let it dry out before re-installation.
Many do just run it down the firewall. I run it back further because of the smell.
your choice.
Old Mar 19, 2008 | 11:11 PM
superduty4x4
I bought 12 feet of hose, mine dumps out right where the cab and bed meet.
Old Mar 20, 2008 | 12:02 AM
mudmaker's Avatar
mudmaker
My X dumps right behind the firewall. Havent noticed any fumes or anything annoying yet.
As far as the original connection to the intake, i just plugged the hole.
Old Mar 20, 2008 | 07:42 AM
Superduty krazy
I've got everything i think i gonna need it just been too cold here to do it yet.....my snowmobile has been apart in the garage, just finished puting the motor in last night ...so maybe over the weekend i will be able to get the truck in to work on it
Old Mar 20, 2008 | 09:58 AM
superduty4x4
OT- what kind of sled do you have? I ride an 03 RMK 800 Vertical Escape 159".
Old Mar 20, 2008 | 04:54 PM
Superduty krazy
01 Xcr 800
AndeyHall
Jul 11, 2011 10:32 PM
Benchwrench
Sep 16, 2010 01:09 PM
shark1979
15
May 3, 2009 08:11 PM
stroken02
20
Oct 2, 2006 08:16 PM
vancouverpower
Aug 30, 2005 04:32 PM
