Engine run's rough
Old Mar 17, 2008 | 11:17 AM
rouschfan's Avatar
rouschfan
Engine run's rough
I have a 98 ranger 4x4, with a 4.0 and automatic. of the morning when i start it up, it run's real rough for maybe a minute or so, probably not even that long, and she seem's to be idling to fast now. Any on have any idea's on what to check ? No codes are present. Any advice would be appreciated
Old Mar 17, 2008 | 11:42 AM
rouschfan's Avatar
rouschfan
I forgot to mention that the truck has 104,000 miles on it. Thank's
Old Mar 18, 2008 | 10:05 AM
rouschfan's Avatar
rouschfan
No thought's ??
Old Mar 18, 2008 | 10:49 AM
Rags's Avatar
Rags
Could be a vacuum leak!
Old Mar 18, 2008 | 10:57 AM
rouschfan's Avatar
rouschfan
Thank's steve, after reading on here about the 02 sensor's i think i am going to replace those, whatcha think ?? Just want to thank all of you good people on here, this rookie learn's alot from you all. : )
Old Mar 18, 2008 | 11:05 AM
Rags's Avatar
Rags
At your current mileage o2's wouldn't hurt but I would think they would throw a code if they were acting out to that extreme.
couple other things to check would be fuel pressure regulator and Idle air control.
Old Mar 18, 2008 | 11:25 AM
rouschfan's Avatar
rouschfan
Where is the fuel pressure regulator located at ? and how would i go about checking it ? Thank's
Old Mar 18, 2008 | 11:35 AM
Bear River's Avatar
Bear River
Former ******
The fuel pressure regulator is located on the front of the fuel rail. There is a schrader valve nearby which allows you to measure the regualted fuel pressure. at idle the pressure should be between 35 to 40 psi. When you disconnect the vacuum line from the regualtor the pressure should jump to over 40, around 45ish. If it does not change, or the pressures are significantly higher than that, the regulator is probably faulty.
Idle air controller is more likely, and easier to replace. Remove it and clean it with some throttle body cleaner. If it improves, then that is the problem. If the problem returns, replace the idle air controller.
Old Mar 18, 2008 | 11:50 AM
rouschfan's Avatar
rouschfan
Thank's, the info from you guy's is appreciated : ) I am gonna go out in the garage and try that, raining here be a good time to do it.
Billy
