lowering a 79
Old Mar 16, 2008 | 10:02 PM
paul 64's Avatar
paul 64
Question lowering a 79
need info over from slick forum i have a 1964 f100 setiing on a 1979 frame
it set higher than i want need to drop it about 3 inches to get back to stock 64 look whats a easy way to do this tks paul
Old Mar 17, 2008 | 12:39 AM
460's Avatar
460
Click this link ---> https://www.ford-trucks.com/forums/s...earchid=403244
Then click on some of the threads... lot's of info.
Old Mar 17, 2008 | 06:58 AM
ford141's Avatar
ford141
460 - Your link doesn't work.
Paul - DJM industries makes a 3" dropped I-beam kit that retains stock springs for a stock ride. Nice kit, I have one on my truck. Do a search in this forum, it has been discussed many times, you should be able to pull up more than a few threads.
Old Mar 17, 2008 | 08:06 PM
427SOHC's Avatar
427SOHC
Check out my 79 F100 gallery photos, however the way I chose to lower mine is an expensive route. I used a Fatman fabrication IFS hub to hub kit. I is still under construction but will offer you some ideas.
There is another post with the use of a 2006 Crown Vic front end under a dentside.
Old Mar 18, 2008 | 12:18 AM
mwvdub's Avatar
mwvdub
I used the DJM kit with smaller tires and got about 4.5 inches in the front.
