Use #2 or jet A whatever, but if what your spraying out your
injectors is too thick and process is more like dribbling... and
your going to end up with coking problems!
Blending is one way to go. However you need to be in a warm climate to do it. You can actually run straight WVO if it is done correctly. Check out http://www.frybrid.com/index.htm for the best information on doing this. He has some very good articles and studies available as well as a well attended forum.
Ken Gardner
