WVO and Kero?
Can I run a 50/50 mix of kerosene and filtered WVO in my 86 f250 6.9L?
i would not run kerosene. it has not lube in it and is bad for well just about all of the upper part of the motor.
Mitch |
i would think the veggie oil would replace any lost lubercation in the kero i think you would still need a tank heater to run it properly though
cheap kerosene?
Use #2 or jet A whatever, but if what your spraying out your
injectors is too thick and process is more like dribbling... and your going to end up with coking problems! |
Running WVO blends is a big gamble. You could lose your engine.
If you want to run WVO do it right. PS I know I will get an argument but you have to decide if you want to take the risk. |
To do it right, it's not as simple as just dumping some filtered WVO and K-1 into the truck's tank. |
Check this site
Blending is one way to go. However you need to be in a warm climate to do it. You can actually run straight WVO if it is done correctly. Check out http://www.frybrid.com/index.htm for the best information on doing this. He has some very good articles and studies available as well as a well attended forum.
Ken Gardner |
