78' 351m problem
Old Feb 26, 2001 | 03:42 PM
scup's Avatar
scup
78' 351m problem
I posted last week about my 78 Bronco I bought with a ton of running problems but almost had them ironed out. Turns out what I waited to do last I should have done first - a compression check. Cyl #5 is dead, 0 compression. Wet test doesnt change a thing. The plug doesnt have any oil on it but it is wet with fuel. I pulled the valve cover to look at the springs and turned the motor over to confirm the valves were opening and closing and the y were. When I got the truck, the header gasket on this head was completly blown. I have no idea how long the previous owner drove it like this. Is it possible a blown gasket could have caused a burnt valve? Since the plug isnt oil soaked can I assume the bootom end is still intact? Thanks for any help.
Old Feb 26, 2001 | 07:24 PM
Bill_Beyer's Avatar
Bill_Beyer
78' 351m problem
0 compression is usually a pretty good indicator of a burned valve(s) and since you already checked to see if the valves were moving then it's almost a sure thing. If it were a holed piston you'd be getting excessive crankcase pressure, i.e. oil out the dipstick, etc. How the valve(s) got burned is anybody's guess. Sounds like the heads need to come off.
Old Feb 27, 2001 | 07:00 AM
Nathan's Avatar
Nathan
78' 351m problem
These heads are bad for burning valves, Ive had two.
Nathan
Old Feb 27, 2001 | 09:26 AM
scup's Avatar
scup
78' 351m problem
Thanks for the input. I'll pull the heads and have them redone. I'll let you all know how it works out. Thanks again.
Old Feb 27, 2001 | 09:32 PM
weldman's Avatar
weldman
78' 351m problem
wahlturfcare
Dec 2, 2016 12:11 AM
Nyquil Junkie
1983 - 2012 Ranger & B-Series
Feb 18, 2016 07:42 AM
MSwitchblade
1997 - 2003 F150
Jul 17, 2015 10:57 AM
MSwitchblade
1997 - 2003 F150
Jul 15, 2015 10:55 PM
AsianSpanker
New Member Introductions
Sep 25, 2008 10:25 PM
