Computer Chips & Tuners
Evolution update software question...
Old Mar 16, 2008 | 01:44 PM
stuckmoto's Avatar
stuckmoto
My Edge Evolution should be arriving tomorrow or Tuesday.
Do I download the "Fusion"or the "Lighting" software or does it simply just depend on the serial sticker on the bottom? The user manual has verbage about Fusion only.
Next question - Should I update the firmware/Calibration/program levels first before ever hooking it up to the truck? Is there any reason NOT to do an update(like better performance from an earlier revision)?
Thanks! 02 F250 S/C
Old Mar 17, 2008 | 01:47 PM
stuckmoto's Avatar
stuckmoto
OK then... I just got the unit, the manual I received with it says to use the "lightning" software. I guess I'll update first.
Old Mar 17, 2008 | 04:42 PM
stuckmoto's Avatar
stuckmoto
Updated...installed...tested...went level 1 first. Shifting was definitely improved(much stiffer). Ran 0-60 & 1/4 mile test and wrote down all my PID's.
Went to level 2... Shifting felt same(supposed to I think), motor felt more responsive!
My 0-60 test dropped a whole second! I know alot of variables are present but there is definitely a difference! Would love to try the level 3, but 91 oct? I can't roll like that!
The way prices are shooting up, don't know if I'll ever see it. Might try to change some variables later, but for now will run @ Level 2.
Old Mar 18, 2008 | 12:40 AM
powerstrokin007's Avatar
powerstrokin007
Fusion is the new updated software. I wouldn't down load it. didn't really see a difference in it. Though it blocks you out of a setting you can change, can't remember what it was. It's not important.
Old Mar 18, 2008 | 12:03 PM
stuckmoto's Avatar
stuckmoto
OK I'll just stick with the Lightning then....Thanks!
