Maryland Chapter Join Chapter, Leader:
March B/S II
Old Mar 22, 2008 | 08:35 AM
  #331
flathead95hp's Avatar
flathead95hp
Originally Posted by jr32560
yeah he seems pretty busy-and being the founder he should want it to run as smoothly as possible-to grow bigger!
I think he would want to see this Chapter grow.
Old Mar 22, 2008 | 08:36 AM
  #332
BIGKEN's Avatar
BIGKEN
Originally Posted by flathead95hp
What did you do with all that loot, Did you blow it all on the twins?
Naah...it was confiscated as I tried crossing the Merry-land border...cyber cops said "What happens in Merry-land...stays in Merry-land"!!!
  #333
jr32560's Avatar
jr32560
hey paul you have many problems with the carb on your 77?
Old Mar 22, 2008 | 08:38 AM
  #334
flathead95hp
I knew they'd stop you at the border, good to know that them cops were on the ball. LOL
Old Mar 22, 2008 | 08:40 AM
  #335
flathead95hp
I did, Had to repair the major vacuum leak in the Brake booster, and just fixed the Accelerator Pump last week. Seems like it's running alot better, but I need to get it adjusted a little better, seems like it want's to bog now and again.
  #336
jr32560's Avatar
jr32560
that is why i am trying to get christian involved-and he is a good mechanic-he has helped me a lot-he knows the newer stuff-well new than what i know-I'm a carb man-and points-I can make them run sweet
Old Mar 22, 2008 | 08:41 AM
  #337
jr32560's Avatar
jr32560
well if ya want I'll take a look at it at the april meet-2 or 4 barrel?
Old Mar 22, 2008 | 08:42 AM
  #338
jr32560's Avatar
jr32560
some are motorcraft carbs some are holleys-and the motorcraft were made either by holley or on there design
  #339
flathead95hp
I got this Mustang here with points in it, Seems like it runs well but I know I can get it better.The guy who had it before me was not very bright, and i got a bunch of vacuum lines that are just plugged off, When It gets warmer, I'm gonna get into it a little more in depth.
Old Mar 22, 2008 | 08:44 AM
  #340
flathead95hp
It's a 2 bbl motorcraft, used to have a 4 bbl on it, but over the years I guess gas mileage is better than horsepower.LOL
Old Mar 22, 2008 | 08:45 AM
  #341
jr32560's Avatar
jr32560
well I may have to make a trip up and check it out-will look around for my old dwell meter-I usually use that as a final point check-and you can play around with the timing and get a lot more out of them
Old Mar 22, 2008 | 08:46 AM
  #342
flathead95hp
I certainly appreciate it, Really want to get the old girl running at peak efficiency, I just haven't had the time to play around with it.
Old Mar 22, 2008 | 08:48 AM
  #343
jr32560's Avatar
jr32560
I've allways found if you don't stomp it the 4 barrel is better on gas-had an old chrysler 2 barrel factory gettinf 14 -went to a 4 barrel and dual points and tuned the **** out of it-re timed it 4 dgrees more advanced and was getting 21 on the highway-old 318-69 sattelite-man wish I kept that car!
Old Mar 22, 2008 | 08:50 AM
  #344
jr32560's Avatar
jr32560
once it warms a bit and i get a little bling in my pocket I'll let ya know-as broke as a joke here lately-guess driving from here to dc and gas is taking it's toll
Old Mar 22, 2008 | 08:53 AM
  #345
flathead95hp
When Dad bought the truck, he took the 4 bbl motorcraft off and put on a Holley 750cfm, I don't know what happened to it, but he said it got 22 mpg then, but now 31 years later, I'm getting around 12-15, but I know I gotta tune her up as it's been years since it was done last.
