390 Engine Ticking
Old Mar 15, 2008 | 11:05 PM
Eagle460's Avatar
Eagle460
Question 390 Engine Ticking
Hey there,
My friend recently purchased (today) a 1974 Ford F-100 with a 390. He told me the previous owner had it rebuit, and since then put 50,000 km on it. The owner also said that he only heard the ticking after the rebuild, and could only hear it at low RPM's.
Any Idea what this ticking could be, if it is serious, I would like to help him figure it out before he starts upgrading to avoid damage. I am going to go hear it run tomorrow.
Thanks!
Old Mar 16, 2008 | 02:31 PM
blue68f100's Avatar
blue68f100
Could be a lifter noise, quite common. Need to know what oil pressure you have at idle. A lot of times if the oil pressure drops to around 10 psi you start to hear them.
If it's done it since it was rebuild I suspect that a lifter may be leaking, valve stem height is to low. Or has a different length pushrod in it, to short. Push rods come in + or -0.050" lengths. Lifters have little ball checks in them, it doesn't take much to prevent them from holding.
Old Mar 16, 2008 | 10:12 PM
Eagle460's Avatar
Eagle460
Alright thanks, the oil pressure is good, and I'm guessing that if the previous owner drove it 50000 km without problems it should be fine.
Old Mar 17, 2008 | 09:31 PM
dodmort's Avatar
dodmort
also check the fuel pump....
