rough idle
Old Mar 15, 2008 | 06:10 PM
ride2die's Avatar
ride2die
Unhappy rough idle
My 89 f150 5.0 has an idle problem. When I start it in the morning it idles at 1500rpms then goes down. But the problem is after driving somewhere and getting back in it to start it up, it starts and shuts off right away. Then I start it again and it stays running (it alwyas stays running on the second try) but the rpm's gofrom 1500 to 500 and keep repeating in that way till I kick it down. But when I go to park it idles fine at 850 rpms. Then in a couple seconds it starts to vary again. I thought it was a vacuum leak but checked everywhere!!!!!! Can Anyone help me.
Old Mar 15, 2008 | 06:38 PM
DJdemon6696's Avatar
DJdemon6696
Try cleaning your IAC
Old Mar 15, 2008 | 08:38 PM
ride2die's Avatar
ride2die
k thanks any other ideas or is that what it is. The oil gauge goes down to lo also forgot to put that in there, dont no if that helps. When i'm going the gauge is normal but when i'm stopped it's at the and throws the check engine light.
Old Mar 15, 2008 | 08:52 PM
ride2die's Avatar
ride2die
it's also only doing after it's warmed up and you go to start it again. other wise it's not doing it at stop signs or anything
