My son and I own a total of 5 '83-'93 pre-powerstroke and (1)'96 psd.The question is can we mate a 6 speed man.from newer trucks or is there something like the Hone overdrive?We are trying to get better mileage.
....The ZF 5 has almost as high overdrive ratio, will still work with the transfer case in your truck and is easier to find clutch discs for.
What he said. Check my gallery for pictures and links to a BUNCH of info on the ZF-5 swap. You looking to convert a 2WD or a 4WD? I have a 2WD ZF-5 for sale in the classifieds.....
ZF 5 overdrive ratio is .77 or .76 depending on which ratio is in the transmission.
Out of three ratios two were .77 and the other was .76.
The ZF 6 has an overdrive ratio of .72, so that is not enough difference that it would be worth swapping in a ZF 6 with the changes you would have to make.
