General Automotive Discussion
Gas hints......
Old Mar 15, 2008 | 11:31 AM
jimdandy's Avatar
jimdandy
Gas hints......
From the net, sent to me by my DIL. jd
I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon.
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some other liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
Old Mar 15, 2008 | 05:07 PM
ubereal2's Avatar
ubereal2
There are some excellent things here, thank you. I'm guilty of running the nozle at the pump at full tilt and have wondered about that before.
Old Mar 15, 2008 | 06:16 PM
bf250's Avatar
bf250
nope, nope and nope.
filling up your little tank on your car is not at all effected by the temperature density thing. don't beleive me? then go fill up a gas can in the morning and weigh it then go fill one up in the evening and weigh it. when talking thousands and thousands of gallons it does make a difference, but we are talking a lot of fuel, like using on boilers or something.
how much fuel you think vapors take up? gallons of it? ridiculous.
what you think filters are for? its not like there is tons of dirt there and its not like filters don't exist and don't work. that goes along with that lame never run your tank low, what, the pick up is from the top? it takes it from the low point anyway.
and where are the numbers at? i see no numbers backing anything up.
Old Mar 15, 2008 | 06:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Pleassseeeee!
Do you have a LOT of Geothermal activity where you live?
Do you REALLY think that the soil temp 10' down is anything other than 58-60*???- regardless of locale, let alone time of day?
That the vapor pressure isn't a constant?
This cr@p belongs with the Dihydrogen Monoxide thread......
Old Mar 15, 2008 | 07:38 PM
ubereal2's Avatar
ubereal2
This has taken a couple turns. Curious how this thread turns out. Some things to me made since.
Old Mar 15, 2008 | 08:55 PM
hofuf's Avatar
hofuf
Sorry but none of this makes sense. I'm thinking you'll spill more from the nozzle than you will save using the "hints".
Old Mar 15, 2008 | 11:10 PM
herman391's Avatar
herman391
Everytime I go and fill up I see this label on the truck that says "volume corrected to 15*C". What the heck does that mean?
