I've got the transmission out of my 91 F-250 and want to know if I should replace the clutch while in there. I've not had a problem with it but want to change it if I should. How thick should it be not to replace it?
You will want to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and scroll over the boards, there is one for your truck. I probably would replace it and the throwout bearing.
