millage
Old Mar 14, 2008 | 10:57 PM
83maverickf-100's Avatar
83maverickf-100
millage
i know it has been reviewd many of times but i cant find milage numbers for a 83 carbed f-100 with 300 ant tips for more millage been driven good since new with yaerly tune ups only 70,000 origanal miles! all i get is 13 mpg at best #'s actually go down on highway but i know its casue the ol 3sp auto don't like 65 mile an hour
Old Mar 14, 2008 | 11:49 PM
Mtthwvn73's Avatar
Mtthwvn73
What kind of gears do you have in the rear? If you don't have an OD you can put some 3.08's in it and drop the RPM's down to a couple thousand.
Matt
Old Mar 15, 2008 | 08:15 PM
83maverickf-100
not sure its the stock 83 f-1oo gears though not sure what they are
Old Mar 24, 2008 | 01:37 PM
83_cda_bronco's Avatar
83_cda_bronco
I have an 1983 Bronco with the 300 and I get about 17MPG. My engine has about 186,000 on it and I have a T-18 4 sp.
Old Mar 24, 2008 | 03:02 PM
wildlife agent's Avatar
wildlife agent
check the catalytic converter if your rig actually has one. I know you aren't supposed to run without a cat but it may be clogged up. you could replace it or "Fix" it. I just "Fixed" mine and my gas mileage went from 11.5 to 16.75 mpg. let the six pack breath. I can't believe all the gas money i have wasted not doing this over the last year and a half that I owned my 95 f-150 4x4, with the 300ci I6. its running real smooth now
Old Mar 25, 2008 | 01:13 AM
Mtthwvn73's Avatar
Mtthwvn73
I "fixed" mine with a sleever bar .
Old Mar 25, 2008 | 02:04 AM
BlackDog&Company's Avatar
BlackDog&Company
87 Bronc, 169, or 269, owned since 156, or 256, KandN, right on the end of the plastic tubes, 8 mm wirres autolite plugs, platinum and non, new pcv, egr, and o2.... ditched the clutch fan in favor of e-fans, 195 degree t-stat, 3 degrees higher than stock... cap rotor, of course...Synth blend oil...
10 mpg, 31's 3.54 gears, and 3speed with O/D manual tranny.
