400M versus 351M piston height
Old May 9, 2001 | 08:25 PM
cm1979's Avatar
cm1979
Does a 400M have large piston height difference compared to the 351M. I want to put the 400M crank in my 351M block. This seems to require a piston change though. I would like some hard numbers if anyone has them.....thanks.
Old May 10, 2001 | 06:40 AM
Nathan's Avatar
Nathan
I dont have the actual dimensions in front of me right now, but you are right, you have to change pistons to go to a 400 crank. There is an article in the tech section here that has the info you need. Check it out.
Nathan
Old May 10, 2001 | 10:06 AM
Bill_Beyer's Avatar
Bill_Beyer
Comp. height on the 400 is 1.650" (same as the 351C). Comp. height on the 351M is 1.947".
Old May 11, 2001 | 10:34 AM
Bill_Beyer's Avatar
Bill_Beyer
