bigfordman70 (Please Read)
Old May 19, 2001 | 08:40 PM
jkt's Avatar
jkt
<There is no emission equiptment at all under the hood of my 79 <bronco. The only thing I had to do to get it running right is <install a 2" phoenalic spacer under the carb to replace the egr <plate, and bump the initial timing up to about 10deg. advance. <BFM
I am having trobles trying to get my 1979 Bronco retimmed after removing the distribator, it is a 400 ci with all the emission equitment removed, you said about 10* BTDC right? a do not have A/C,Do you? if so will it be diferent right?
Old May 20, 2001 | 10:51 PM
Ben_E's Avatar
Ben_E
