302 Question
Old Mar 13, 2008 | 11:21 PM
Chuck-AZ's Avatar
Chuck-AZ
302 Question
I just acquired a 302 engine. The casting number (located on the right lower side of the block, extreme rear) "drivers side, not the starter side" - is E6 SE BA I have decoded this to be a 86 engine ?? I'm not hung up with the location, but I don't think it's in the correct place? MORE - On the top of the block, at the rear of the manifold sealing area it's stamped GKB 00771 What do I have?
Also this engine is .040 over bore, is this the limit for this engine?
Thanks
Old Mar 14, 2008 | 04:42 AM
HemiEater's Avatar
HemiEater
should be above the starter.. look again. you can go .060 some say thats way too much, might be if you pushing it to 500hp, but hey they make the pistons and ring for it.
Old Mar 14, 2008 | 11:07 PM
Chuck-AZ's Avatar
Chuck-AZ
No numbers above the starter, only a big (1/2 inch) "S" in cast. It's not fitting the normal identification system.
Thanks
Old Mar 14, 2008 | 11:35 PM
baddad457's Avatar
baddad457
E6SE is a roller 5.0 block, they were used up into the early 90's. I had a 40 over reman, it ended up splitting the #4 cylinder wall. This was a 1/2" long crack midway in the wall and it did it at 7500 rpms. The numbers behind the intake are the original vehicle's VIN numbers.
Old Mar 15, 2008 | 05:23 AM
HemiEater's Avatar
HemiEater
pics...........
Removal of the starter is necessary to see the number
Old Mar 15, 2008 | 08:22 AM
baddad457's Avatar
baddad457
Hemieater----the 5.0 roller block casting numbers are cast differently but in the same general location. The flat area where the old numbers were, isn't there on the rollers. If I wasn't so illiterate on this thing, I'd post pics.
Old Mar 15, 2008 | 08:08 PM
Chuck-AZ's Avatar
Chuck-AZ
baddad454
Thanks for the information. I was given this engine to replace a 1981 255 CID Ford engine-in a street rod (that information may start some new threads?) I haven't had time to do much more than removing the heads. The engine was rebuilt by a novice and never ran because it was locked up. It has hydraulic lifters now and surfice rust in the cylinders. I hope it can be repaired. If you want me to keep you updated, let me know. Check out my posts in the Ranger section to see what my real problem has been.
Thanks again - you have been a great help!!!
Old Mar 15, 2008 | 08:13 PM
Chuck-AZ's Avatar
Chuck-AZ
remember I'm a new user
Is it OK to attach a jpg file ???? -If not how do I send a picture ??? If so I will take some pictures of this roller block so you can see.
Thanks
Old Mar 15, 2008 | 08:21 PM
HemiEater's Avatar
HemiEater
send them to me I can post them on my server for you or you can start a gallery here
click on user-cp and then edit gallery... have fun..
Old Mar 15, 2008 | 10:20 PM
Chuck-AZ's Avatar
Chuck-AZ
baddad457 -- sorry about the 454 !!!
HemiEater -- For some reason I cannot email you the pictures, I don't have the authority to do that. I will try the gallery?
Thanks
Old Mar 16, 2008 | 05:46 AM
HemiEater's Avatar
HemiEater
393clevor@metrocast.net
Old Mar 16, 2008 | 08:19 AM
baddad457's Avatar
baddad457
Thanks
HUH?????? Sorry, you've completely lost me on this. Only 454 I ever had was a stroked and poked 427 Ford.
Old Mar 16, 2008 | 09:47 AM
Chuck-AZ's Avatar
Chuck-AZ
baddad454
This is the 454 I was sorry about. I have fat fingers at times.
Old Mar 16, 2008 | 11:23 AM
baddad457's Avatar
baddad457
I never noticed it.
Old Mar 16, 2008 | 12:01 PM
HemiEater's Avatar
HemiEater
pics ....
