wiring
Old Mar 13, 2008 | 10:27 PM
cwis's Avatar
cwis
wiring
Hi, I am want to wire a box light for my 08 F150. I would like to wire the light to have power all the time (switch is on the light), Does anybody have any advice for an easy way to do this, I really didnt want to run a wire all the way back to the fuse panel plus its really tight in there. Thanks
Old Mar 28, 2008 | 11:52 AM
okgearhead's Avatar
okgearhead
If your talking about the bed of your truck, you could tap into you trailer connectors 12 volt supply, if you have a tow package.
Old Mar 28, 2008 | 01:57 PM
Franklin2's Avatar
Franklin2
The factory trailer tow supply goes on and off with the keyswitch. Running a wire from the light directly to the battery will probably be the easiest way, with a inline fuse close to the battery.
