dead rich
Old Mar 13, 2008 | 08:28 PM
ssidney's Avatar
ssidney
dead rich
is it poss. for eec iv to cause rich cond. due to low comp. in only 1 cyl. (by over compensating)
Old Mar 13, 2008 | 09:47 PM
Conanski's Avatar
Conanski
A cylinder that doesn't have enough compression to ignite the fuel will result in very rich exhaust..
Old Mar 13, 2008 | 10:17 PM
ssidney's Avatar
ssidney
by the looks of the plug it has enough (80lbs) to light the mixture, it's just the only thing (other than the injectors or ecm) that would make sense, everything else has been checked and double-checked
Old Mar 14, 2008 | 04:43 AM
EPNCSU2006's Avatar
EPNCSU2006
If there's a misfire, the additional oxygen from the uncombusted mixture signals a lean mixture as it passes by the O2 sensor, leading the computer to richen the mixture.
Old Mar 16, 2008 | 07:01 PM
ssidney's Avatar
ssidney
thanks for the help...figured it out -bad gas (old gas)
Old Mar 16, 2008 | 08:41 PM
boggerted's Avatar
boggerted
uhhh, maybe you should fix the cylinder with 80psi compression???? LOL
Old Mar 16, 2008 | 09:36 PM
ssidney's Avatar
ssidney
compression came up when cylinders weren't being washed by gas that wouldn't burn
