Sponsored by: Auxito
5.4L engine noise
Old Mar 13, 2008 | 08:36 AM
MCLEM's Avatar
MCLEM
Question 5.4L engine noise
My 2000 F150 4x4 is making a ratteling noise above 1500 rpm. I've tried using a stethescope but can't pinpoint the problem. It never makes noise until warm,seems like a bearing except it doesn't rattle under a load at low rpm, for example, powerbraking. The amount of load doesn't affect the severity of the rattle either, it sounds pretty much the same no matter how hard I accelerate, with the exception of it's frequency which increases with rpm. Another strange fact is that it rattles when decelerating such as coasting on the interstate or after accelerating hard and letting off. The oil pressure seems good(according to the gauge anyway), I've unhooked coil wires to try to pinpoint a cylinder to no avail, still sounded the same( throttle held open at 2000 rpm). Any help would be greatly appreciated!!!!
Old Mar 14, 2008 | 12:08 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
A cracked or loose flywheel perhaps?
Old Mar 15, 2008 | 01:40 PM
fruth04's Avatar
fruth04
could be 1000things, my 03 had an exhaust manifold gasket blow out, sounded like a playing card in the spokes of a bike (pop/ticking) if u crawl under and look with a flashlight you might see excessive blackness around one secluded area where it blows out. when it runs it almost sounded ontop of the motor...
Old Mar 18, 2008 | 02:05 PM
MCLEM's Avatar
MCLEM
It definitely sounds like something internal, especially when I rev it up in park. I took off the flywheel cover but can't see anything except the starter ring, pried on it with a bar and it seemed tight. I checked for exhaust leaks seems to be okay. It's more of a "rattle" than a tick or click. Thanks for the help, any tips are greatly appreciated!!
morris_506
1997 - 2003 F150
15
Jul 30, 2023 02:53 PM
Anthony Polsinelli
May 6, 2018 05:00 PM
Schnurrbart
28
Mar 11, 2017 07:55 PM
spike150
Apr 4, 2016 07:35 PM
Crazy J
6.4L Power Stroke Diesel
Mar 16, 2015 09:52 PM
