Had to shift?
Old Mar 12, 2008 | 09:06 PM
ech0sh4y's Avatar
ech0sh4y
Had to shift?
Hey guys i have a M5OD tranny, i just changed the clutch, flywheel, pilot bearing, ect.... after 100 miles or so it' is hard to push the tranny into gears. It kind of sticks? Is there an adjusment for this or somethign I can grease?
Old Mar 13, 2008 | 12:15 AM
85e150's Avatar
85e150
Plenty of the right kind of oil? These use ATF I think. Double check.
Old Mar 13, 2008 | 08:03 AM
ech0sh4y's Avatar
ech0sh4y
Yes, it's full! I put in ATF as well.
Old Mar 13, 2008 | 12:35 PM
subs1000w's Avatar
subs1000w
probobly the clutch not disengaging all the way does it do it in all gears or just 1st/rev
did you replace the slave cylinder if so i would try bleeding it some more
Old Mar 14, 2008 | 10:19 PM
ech0sh4y's Avatar
ech0sh4y
Reverse always grinds a little bit when i put it in, all of them are hard and the clutch seems to engage or catch right away but u have to have it all the way to the floor, is there an adjusment? And when you bleed the clutch you take the cap off the resevor and crack the bleeder and let it gravity bleed correct?
