fuel injection
Old Jun 19, 2001 | 03:49 PM
whomrig's Avatar
whomrig
fuel injection
Old Jul 21, 2001 | 03:44 AM
dslman's Avatar
dslman
fuel injection
Will the factory multi port from a 460 fit a 400? I want to retrofit fuel injection onto my 400 and need advice.
Old Jul 21, 2001 | 01:07 PM
Bill_Beyer's Avatar
Bill_Beyer
fuel injection
The manifolds won't interchange so you're out of luck there. You may want to look into using an aftermarket system like Holley or Howell but remember that in order to make it a closed loop system you have to install EGO sensors in the exhaust and if you retain the stock AIR system then it's going to mess up the readings and the system won't function properly.
