Fusible links
Old Mar 12, 2008 | 04:25 PM
Grandpa's1983's Avatar
Grandpa's1983
Fusible links
Hello electrical guru's, my question is can a fusible link be replaced with an inline fuse? My 1983 F150 has some questionable looking wiring by the starter solenoid (the 16 gauge orange wire) and I was wondering what would be the best way to replace it. Thanks for any help.
Old Mar 12, 2008 | 04:47 PM
zx250's Avatar
zx250
Of the next Riffraff East
The advantage of fusible links are they can withstand higher amp draws for longer periods of time. You can use an inline fuse but on a solinod it will probably blow if starter turns very long. Look HERE and HERE and HERE for info and replacement links. You can also get them from most local parts stores. Just be sure you use the same length and size as original.
Old Mar 12, 2008 | 05:46 PM
Franklin2's Avatar
Franklin2
You can use fuses. The first big question no one can answer is what value fuse matches each fusible link? I have never seen an offical chart or anything, so what you can do is guess at the loads, and also go by the size alternator you have.
Generally speaking, the fuses to replace the fusible links are going to be very large. In the neighborhood of 60, 70 up to 100 amps. So you will have to use maxi fuses. If you look at the newest vehicles, a lot of them have gotten away from the fusible links, and have large maxi fuses in a underhood fuse box.
So if you have a 60 amp alternator, I would use at least a 60 amp fuse at the main fusible link at the starter solenoid connection.
Old Mar 12, 2008 | 06:35 PM
Grandpa's1983
zx250 ~ thanks for the links they were very helpful
Franklin2 ~ that's a good point about what size of fuse would work, I hadn't thought about that. I think I will probably just replace it with a new fusible link just to be safe.
Old Mar 12, 2008 | 06:43 PM
zx250's Avatar
zx250
No problem.
bbf150
Electrical Systems/Wiring
Feb 12, 2015 06:03 PM
Island Time
Jul 6, 2014 07:26 PM
Ken Blythen
Jul 23, 2011 03:13 PM
papadelogan
Jan 3, 2008 04:52 PM
