New guy w/problem
Old Mar 12, 2008 | 03:08 PM
Edigan's Avatar
Edigan
New guy w/problem
Hi everyone, I am new here. I work at a gagrage and do most of the electronic engine diagnosis on our heavy trucks. Recently we bought a scan tool for our smaller stuff, it reads obd 1 and obd 2. Here is my problem. The scanner works fine on obd2, and on my eec4 stuff at home, but it won't read any of our eec4 stucks at work. I have tried multiple scan tools, and none of them will read anything. Has anyone ran across this problem? Thanks in advance.
Old Mar 12, 2008 | 03:33 PM
DJdemon6696's Avatar
DJdemon6696
No Codes?
<WIDTH=750PX>The famous “No Code” situation that people describe usually ends up being user error. Not that I blame anyone for not getting codes, but the Ford computer outlasts everything else on a vehicle from bumper to bumper. So PLEASE read how to perform a Self-Test and getting Trouble-Codes before tearing the vehicle apart. Replacing computers more than once on a vehicle is not an acceptable repair, other problems exist in that vehicle. Most “No Code” situations are caused by wiring problems. I have created a list of things to check. Hopefully you can get this sorted out with out burning up computers or beating your head against a wall.
•Check Battery voltage, must be above 10.5 volts.
•Replace battery if not.
•Check battery connections, corrosion, ground faults, and wiring.
• Fix all wiring.
•Check alternator output, must be between 13.5 and 14.5 volts.
•Replace Alternator if not.
•Any recent voltage irregularities from electrical charging system can cause failures.
•Replace alternator and any damaged circuits, wiring, and components.
•Check fusible links on Starter Solenoid if equipped.
•Check fuses and surge protection diode in under hood Power Distribution Box.
•Replace any fuses, diodes, and links if needed.
•Check EEC relay, must show battery voltage when engaged.
•Replace relay and damaged wiring if not.
•Make sure pin 30 on the computer is hooked up correctly.
•Manual transmission computers need to sense SIG-RTN on pin 30 when in neutral.
•Automatic transmission computers need to sense Ground on pin 30 when in neutral.
•Electronicly controled automatic computers need an operational Manual Lever Position Sensor (MLPS)
•Check aftermarket devices like alarm system connected to engine or computer components.
•Restore engine and computer system to original configuration.
•Check aftermarket computer chips and other plug in controls.
•Any chips or controls that impede basic engine and computer function need to be removed.
•Restore computer and harness to original configuration.
•Disconnect computer and inspect for damaged or pushed out pins, corrosion, loose wires.
•Replace computer if visually damaged, repair any damaged pins in harness.
•Visually inspect the ENTIRE engine and computer wiring harness and connections for corrosion, ground faults, shorts, physical damage, and general condition.
•FIX ANY & ALL PROBLEMS!
•Check Self-Test Input circuit on Pin 48 at computer harness for shorts to ground.
•Replace faulty wiring.
•Remove check engine light bulb and check Self-Test Output circuit for shorts to ground.
•Check Engine Light for damage.
•Replace faulty light bulb.
•Measure resistance between battery negative post and pins 20, 40, and 60 at the computer harness.
•Resistance must be less than 5.0 ohms.
•Replace faulty wiring between computer and battery if not.
•Turn key to ON with engine OFF and computer removed. Measure voltage on pins 1, 37, and 57. Must be above 10.5 volts and within 1.0 volt of each other.
•Turn key ON with engine OFF and computer reinstalled. Measure voltage between Pin 26 and 46 (voltage reference and signal return) must be between 4.0-6.0 volts.
•Replace faulty wiring and sensors.
•Measure resistance between Pin 46 and Pins 40 and 60 at the computer harness, must be less than 5.0 ohms.
•If all the wiring and sensors check out, Replace the computer.
TAKEN FROM FORDFUELINJECTION.COM
Old Mar 12, 2008 | 05:10 PM
quicklook2's Avatar
quicklook2
WOW! now that is some list of what to check.
Old Mar 12, 2008 | 05:40 PM
Edigan's Avatar
Edigan
Surprisingly, I have checked a good number of those things. It is just the trucks at work that have problems. I can get codes out of other trucks. I know that radar can mess with eec4. We don't have radar, but we have two way radios. I unhooked it thinking it may be the problem, but it didn't fix it. We even have two depos that are 12 miles apart and it won't work on their trucks either. I was wondering if the two way radios might have damaged the diagnostic part of the ecm.
Old Mar 12, 2008 | 07:04 PM
MisterDave2's Avatar
MisterDave2
Go DJ, that's a great list! Edigan, I'm pretty good with the radio thing and at one time in the 1980s I used to work for both Motorola and GE dealers and worked alot with police and fire radios (talk about nightmares). The short answer is I doubt it. Those radios could interfere or cause mis readings and malfunctions during transmit operation, but a permanant damage is really unlikely. I think possibly the code reader is maybe just not getting along with those trucks, I am the wrong person to discuss that so I won't even try, I don't even read my own codes I go to Autozone.
