inner fenders???
Old Mar 12, 2008 | 02:40 PM
fitzwell's Avatar
fitzwell
inner fenders???
So, i saw a 42-47 1 ton in a wrecking ward today...and it still has the inner fenders. Will these swap/fit on a 1/2 ton?? Main concern is the fneder radius, i know i will have to trim to fir around the suspension.
thanks,
mike
Old Mar 12, 2008 | 07:29 PM
Fix's Avatar
Fix
Pretty sure they're the same.
I have some off of a 1 ton, on my half ton, but my truck isn't exactly stock and I had to cut em up some anyway.
If I recall correctly the outside wheel opening on the fenders themselves is the only difference between the big and little trucks. The part that bolts to the cab and the core support is the same. The inner fenders fit as well.
Maybe someone can verify.
Old Mar 13, 2008 | 12:20 AM
46fordtruck's Avatar
46fordtruck
Fix is correct, the inner fender panels will interchange with no problems, as stated, it is the radius of the wheel opening on the fenders themselves that is the difference between 1/2 ton and 1 ton front sheetmetal.
Old Mar 13, 2008 | 08:29 AM
fitzwell's Avatar
fitzwell
Outstanding..
thanks guys.
