Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
trailer lights
Old 03-12-2008, 02:25 PM
Escape055's Avatar
Escape055
Escape055 is offline
trailer lights
I know some of you have installed a trailer light plug and was wondering if you have to put a fuse in the fuse box. I read somewhere where you had to put one in the #1 position. I looked in my fuse box last night and the #1 is open. I doesn't even wires ruinning to it for a fuse. Also does anyone know where I can get a diagram for the fuse box that tells what each fuse controls? My doesn't have one. I know it's usually on the back of the cover but mine is not.
Old 03-12-2008, 06:13 PM
pacrewchief's Avatar
pacrewchief
pacrewchief is offline
I wired mine the old fashioned way, direct from the tailights. You will need two diodes available at any parts store to allow the seperate stop, turn, tail lights on the Escape to power the combined stop, turn, tail lights on the trailer. It takes a little time, solder all of your connections, use "heat shrink" tubing on the joints not tape and you will not have a problem. Mine has been in place for two years and works well. Good luck.
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-26-2009 08:35 PM
lud04X
05-18-2008 11:56 AM
taylor0987
01-17-2005 03:35 PM
mattisjd
1983 - 2012 Ranger & B-Series
10-13-2004 09:56 AM
springer9861
Electrical Systems/Wiring
04-19-2004 03:26 AM
Quick Reply: trailer lights
