Banks Six Gun
Old Mar 12, 2008 | 02:12 PM
PowerStroker?'s Avatar
PowerStroker?
Banks Six Gun
I found a truck that I'm looking at that has a Banks Six Gun system installed in it. http://store.bankspower.com/Categori...8-710a2fa8b3a6
I was wondering if anyone knows whether I should avoid it or if if it was a good system or what. I know everyone here prefers their AIS or their 6637 or whatever it is from NAPA, but should I plan on replacing the intake if I do buy the truck?
Old Mar 12, 2008 | 02:18 PM
HKusp's Avatar
HKusp
Check the engine out with a mechanic that you trust, buy the truck if he says it's solid. Look it over for this stuff: things:https://www.ford-trucks.com/forums/5...questions.html
If it passes the test,then sell the 6 Gun tuner to some unsuspecting dupe and buy the DP. You'll like it way better. The exhaust and intake are probably good performance wise, just overpriced, but since you aren't the one paying for it, no biggie.
Old Mar 12, 2008 | 02:30 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Jason pretty much sumed it up.
Old Mar 12, 2008 | 02:33 PM
bdrummonds's Avatar
bdrummonds
Ditch the intake, it is a drop in filter that utilizes the poorly designed stock air box. It is not the filters fault, it is the Airbox from the factory not being able to provide a tight seal and letting dust pass thru to the turbo.
Inspect turbo very carefully before buying this truck.
Old Mar 12, 2008 | 02:34 PM
PowerStroker?
I haven't spoken to the person that owns the truck, but it is an 01 automatic.
The ad says that he replaced the trans so that should solve the no 2nd gear issue that some might have right?
Also what would cause the turbo on a truck with this installed to be any worse than a stocker?
Old Mar 12, 2008 | 03:31 PM
bdrummonds's Avatar
bdrummonds
Like I mentioned before Its the airbox around the filter that is of poor design, It allows unfiltered air to go directly to the turbo blades. Check the turbo blades very closely for a sandblasted look, rough edges, nicks or bends. the primary job of a turbo is to suck in air, compress it and feed it directly to the cylinders. A non sealing (whether it be because the lock tabs have broken, or are just not holding tight.)air box allows fine dirt and sand particles into that engine which tend to contaminate the oil, and wear internal parts more quickly.
Old Mar 12, 2008 | 05:00 PM
PowerStroker?
Well then I think I'll pass on that truck. There's plenty of others that won't have that issue.
Old Mar 12, 2008 | 05:03 PM
bdrummonds's Avatar
bdrummonds
No, dont just pass on it, go and inspect it. ALL 7.3s had the issue with the poor fitting airbox lid. It was just made worse by after market drop in filters that were not the correct dimesions. Mileage, and maintenance will be the deciding factor on a used truck.
