Air filter change
Old Mar 12, 2008 | 01:16 PM
danocross's Avatar
danocross
Air filter change
I am getting ready to change the air filter on my '03 PSD 6.0. Two questions come to mind for you folks in the know. I am not a mechanic, I change the oil and fuel filters, that is about it.
1. Do you trust the "minder"? Mine has not really moved in about 20,000 miles, and I drive on a dusty Arizona road. It is reading about "65%", whatever that means. It has been around 30,000 miles since I changed it.
2. Why is it so hard to replace the filter? I had a mechanic friend help me, this guy is a great mechanic, and we really struggled getting it in. Way harder than on a 7.3...or were we doing something wrong?
Thanks for any input or advice.
dc
Old Mar 12, 2008 | 01:40 PM
BobsF350's Avatar
BobsF350
pull the coolant lines off that run to the expansion tank.losen clamp on rubber hose to ABS plastic tube going to turbo.pull the rear part off the filter assembly sraight up and out.the front part up an inch and forward then the filter element straight up and out
takes me 5 mins
