Sponsored by: Real Truck
430 rear end
Old Mar 12, 2008 | 08:45 AM
reckseck's Avatar
reckseck
430 rear end
Does anybody out there know what is involved to change my 430 rear end to a 373. I have a 06 F-350 6.0 diesel
Would appreciate any info.
Thanks
Old Mar 12, 2008 | 09:55 AM
cgl's Avatar
cgl
Is it a Dually? 4x4? why would you want the higher gears? You'll obviously need the new ring and pinion and possibly a new carrier, depending on what gear manufacturer you're getting. It's usually a shop job and it'll cost around $1000, parts included.
Old Mar 12, 2008 | 11:04 AM
reckseck's Avatar
reckseck
Yes it's a dually, I need to get some better fuel mileage, so elect the higher setting. The 430 rear end has me down to 12.4mpg
Old Mar 12, 2008 | 11:17 AM
mizzitch's Avatar
mizzitch
get a gear vendor's underdrive unit - it will cost about the same as switching the gearing if you have 4x4
Old Mar 12, 2008 | 11:27 AM
MitchPeters's Avatar
MitchPeters
Why does 500+ lbs/ft of torque need a 4.30 axle?
Old Mar 12, 2008 | 11:35 AM
1 Ton Tommy's Avatar
1 Ton Tommy
I have pondered giving up my 3:73 gears on my '06 F-350 diesel for more low end starting power. If you pull with your truck, and starting loads is an issue, I wouldn't give up the lower gear ratio. Poor mileage stinks, but not being able to pull really, really, stinks!!! I am only getting 14 mpg with my single axle and the 3:73.
Old Mar 12, 2008 | 03:17 PM
edjunior's Avatar
edjunior
Sheesh, 12.4 with a dually sounds pretty good. I really don't think with a 3.73 you're going to do a whole lot better, but if it makes you feel better, more power to you. You should take it to a shop and get an estimate on the price there. The parts alone are gonne be around 400 - 700 dollars (if I remember correctly).
Old Mar 12, 2008 | 09:07 PM
MitchPeters
You could do a test first. Find a set of taller tires to bolt on and run a few tanks of fuel to see what the mileage does. There is a tire/gear calculator out there to see what size tire will equal what gear and to calculate the miles also.
Old Mar 13, 2008 | 07:44 AM
mizzitch's Avatar
mizzitch
the rolling resistance of bigger tires and reduced aerodynamics will cause error in that test - plus it's hard to find bigger tires to fit a dually
renyren
25
May 8, 2018 12:41 PM
TomD1
Jan 3, 2017 12:53 PM
bholman
6.7L Power Stroke Diesel
32
Nov 23, 2015 11:29 PM
TSmylie
Aug 22, 2015 07:53 PM
BlueKnight
Mar 4, 2005 11:54 AM
