Sponsored by: Real Truck
Acetylene Torch & Exploding Ball Joint
Old Mar 11, 2008 | 08:57 PM
Jim59's Avatar
Jim59
2002 F250 SD 4X4 CC
My son and his friend were changing the driver's side ball joints on my truck today. The castle nut on the upper joint was hard to remove, and the ball joint's shaft began to spin with the nut. ViceGrips, etc did not work, so he used the torch to cut through the shaft, just below the threaded area.
It cut though easy enough. The rubber boot (he assumes) was burning and he extinguished it. He removed the knuckle from the truck and laid it down next to him. Approximately two minutes later .... super loud boom. The remaining part of the ball joint's shaft exploded out of the joint's body, punched through the wood overhead door about 20 feet away, and lodged deeply into the garage's block wall. My son's friend saw the knuckle jump about a foot off of the ground as it happened. Both boys ears' were ringing from the blast (even though they were outside in the driveway).
The knuckle was sitting on the ground between them, as they were kneeling down working on the truck. If that steel projectile would have hit one of the boys in the leg ....... or in the chest ....... or in the head ........
I was in the house at the time. I heard the blast .... thinking that maybe the oxygen tank exploded or something. I said .... Oh My God. Then I heard the boys laughing, and I said .... Thank you God.
I'm only writing this as a friendly precaution to everyone. The ball joints were original .... therefore sealed (no grease fitting). But when things are "sealed," like joints, roller/thrust bearings, etc .... it is done with hard rubber (I think). But, someway, somehow .... the ball joint became so tightly sealed, and I assume the internal grease was cooking from the heat and producing gas/pressure, and it turned into a potentially tragic accident. I would have never thought it.
Jim
Old Mar 11, 2008 | 09:02 PM
TARHEEL57's Avatar
TARHEEL57
thank you for posting this. Thank goodness no one had to get hurt to discover this.
BobsF350's Avatar
BobsF350
those kids are lucky,
Old Mar 11, 2008 | 09:52 PM
redford's Avatar
redford
FTE Leadership Emeritus
Damn....glad those guys weren't hurt.
Old Mar 11, 2008 | 10:22 PM
92f150I6's Avatar
92f150I6
I saw a ball joint from a chevy lumina do that once. don't use torches anymore.
Old Mar 11, 2008 | 11:08 PM
unrulee's Avatar
unrulee
I saw a guy where I used to work do that on a tie rod end of a big forklift......scary stuff!!!
Old Mar 11, 2008 | 11:37 PM
99f350sd's Avatar
99f350sd
Thanks for the heads up! Glad no one got hurt..
Dick
Old Mar 12, 2008 | 07:11 AM
F350-6's Avatar
F350-6
Glad no one was hurt, and thanks for sharing. This is the kind of thing we should all keep in mind. Grabbing a torch for a stuck piece is a common thing. This is one of those pieces of knowledge you don't want to learn the hard way. Rep points sent.
Old Mar 12, 2008 | 09:39 AM
rbloodhound's Avatar
rbloodhound
Thanks for sharing. I never would have thought that the ball joint would explode like that.
Old Mar 12, 2008 | 12:59 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I've had u-joints do that too. The idiotic nylon-retained GM ones that you have to heat just to melt the nylon that retains the caps.
Old Mar 12, 2008 | 04:35 PM
blakeman's Avatar
blakeman
I have never even heard of such a thing happening. Will have to remember that in the future...
Old Mar 12, 2008 | 06:17 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
bump, thats scary stuff
Old Mar 12, 2008 | 07:07 PM
GregsSD's Avatar
GregsSD
The best way to remove the nut when it just spins is to use an air impact wrench, it spins fast enough to take it right off.
Old Mar 13, 2008 | 01:51 PM
rugerman's Avatar
rugerman
Sounds like my youngest son, give him a box of ball bearings and a feather duster and all you get back is iron filings. rugerman ps glad everybody is ok.
Old Mar 13, 2008 | 03:57 PM
Turbokid15's Avatar
Turbokid15
Any pics of this little accident
