Sponsored by: Auxito
Need Help
Old Mar 11, 2008 | 09:30 AM
Sarge261's Avatar
Sarge261
Need Help
Hey Guys,
I am working on a friends truck and it has a stumble and a pop under load. Doesnt happen all the time. I have already replaced the plugs and wires with new motor craft parts. Anything out there that may be of help I would appriciate it. Its a 2001 F-150 4.2 v-6. It also has a new fuel filter as well. Automatic 4x2. I didnt know if there was a bulletin or updated calibration to fix this or maybe the coil is shorting out. The plugs on the 1&3 cylinders were carbon tracked last time they were replaced. Also the CEL does not come on and the scan tool that I have doesnt allow me to view misfire data.
Thanks,
Sarge
Old Mar 14, 2008 | 01:52 AM
ReAX's Avatar
ReAX
Pop as in fuel igniting in the exhaust? That would tell me either the cylinder isn't firing or has too much fuel in it. A rich/not igniting cylinder's exhaust port should be colder than the rest. If you have a IR thermometer you can read the temps, or you can spray water on the manifold and the cooler ones shouldn't steam as quickly.
Old Mar 14, 2008 | 02:20 AM
LxMan1's Avatar
LxMan1
Perhaps try cleaning the MAF?
