Sponsored by: Real Truck
Changing tires
Old Mar 11, 2008 | 08:58 AM
kyblev's Avatar
kyblev
Changing tires
I have a 2004 F-250 and bought it new off the lot. It came with LT 265/75R/16 tires on it. There seems to be a lot of room left in the wheel well. Wondering if I could go to 285/75R/16 without any altering or wheel rub?
Old Mar 11, 2008 | 09:14 AM
WildWildWest's Avatar
WildWildWest
Welcome to FTE!!
The 285's will fit fine - should be about 33" high vs. 31.5" high and you won't have any issues rubbing on the leaf springs turning or other clearance issues. Your speedometer will be out slightly but you can adjust that with a good tuner or even a cheaper programmer that only changes the speedo for your new tire size.
Old Mar 11, 2008 | 10:02 AM
ffadragon's Avatar
ffadragon
You can even go up to a 295 with no problems. If you have the plow package some people on here say you can run 305 with a little rub at full lock.
285's and 295's will be no problem.
Old Mar 12, 2008 | 08:46 AM
kyblev's Avatar
kyblev
Thanks for the info. My truck has the XLT package added to it, and the tires looked really small for the truck. Thanks once again for the info. Just got it back from the dealer last week. Bad EGR only 53000 on the 6.0 diesel. I can only hope this is not the beginning of troubles.
Old Mar 12, 2008 | 12:50 PM
rugermack's Avatar
rugermack
I ran 305's on my wifes 04", they didn't rub.
Old Mar 12, 2008 | 12:57 PM
TARHEEL57's Avatar
TARHEEL57
I am planning on going with 285's on my 2004 F-350 cc 4X4 SRW when my current 265's give out.
Would I be able to go larger than that without rubbing since mine is a F-350 ?
Chad
Old Mar 12, 2008 | 01:24 PM
preppypyro's Avatar
preppypyro
I went with 285, 17's on my 03 and they work awesome, no rubbing at all either.
Old Mar 12, 2008 | 01:36 PM
ffadragon's Avatar
ffadragon
Tarheel read above post. You can run 295's and some can run 305's with out problems
Now you second question, There is no difference on the front ends between 250 and 350., only the rear is different.
Now if you have a plow package or what some call X springs in the front the 305 will clear easy.
Remember 305 is the same height as a 285 just and inch wider tire. That is why some 305's rub on the leaf spring at full lock.
Old Mar 13, 2008 | 09:44 PM
hawaiiv6's Avatar
hawaiiv6
Thumbs up
I have a 03' 250 4x4 standard springs and stock rims. I run 305/70/16's no rub at full lock. Go for it.
Old Mar 13, 2008 | 10:14 PM
fyrmnk1's Avatar
fyrmnk1
I went with the 285s when I replaced mine. That was what I was told was the max. size I could do without other changes.
Didn't alter the speedo much at all, checking it with GPS, it is only about 1 mph off.
