4wd Low/ Transfer case problem
Old Mar 11, 2008 | 06:23 AM
JustMyLuck's Avatar
JustMyLuck
Long story short, ton of snow in Ohio and used the 4wd low on my 2000 X v10(126,000 mi) for the first time in a year. Left it(by mistake) in 4wd low overnight and now it wont switch back to 2wd. The switch doesn't make a noise and no 4wd lights on dash ( the overdrive light does flash if I drive it). Read this forum and checked fuses(fine) and bought a new transfer case motor. Problem is that I took the old motor off without issue, but I cant turn the shaft on the case to align with the new motor, the thing wont budge. Is there a way to manually release the 4wd so I can get it to my shop. Thanks for any help.
Old Mar 11, 2008 | 07:24 AM
partsetal's Avatar
partsetal
One suggestion is to keep pressure on the shaft while turning the front and rear wheels back and forth.
Old Mar 12, 2008 | 01:56 PM
JustMyLuck's Avatar
JustMyLuck
No luck moving the shaft so called the local Ford dealer. The nice lady in service said to check the relay and solenoid for the transfer case motor, but couldn't tell me where they are. I hooked up the new transfer case motor and it doesnt engage when I move the swith either so i am thinking it is in the wiring somewhere?
Old Mar 13, 2008 | 05:34 AM
JustMyLuck's Avatar
JustMyLuck
Problem solved, got the new motor on the transfer case and cleaned the connections to the motor and she works like a charm. Thanks for the help.
Jack Peterson
Dec 27, 2016 12:51 PM
FreeDevin
Sep 5, 2016 08:12 PM
alduane
1983 - 2012 Ranger & B-Series
20
Aug 4, 2016 07:57 AM
underdogl3
Feb 18, 2016 07:00 PM
Omarzero
Apr 20, 2015 09:10 PM
