I am in the process of swapping a 400 in place of my worn out 351m, how much of a torqe and horsepower increase can i expect? , and what are your guesses on the total power output of a 1979, fully remanufactured, fully stock 400? horsepower and torque, and do you think if I treat this engine right it will last? how long? thanks, ya'll
Comatose is about right! Had two cylinder with under 50lbs compression, three burned exhaust valves, and 5 worn down cam lobes. not to mention the crank was severly scored and had to be replaced. but it still purred like a kitten....okay maybe a sick kitten, but it purred.
they were rated from 150-178 hp from the factory. if you have a clue and can read, one can get 380-700hp easy out of a 400c/m. the otrguq was 330 rated, and one can get 350-600+ ftlbs. its east to get this, hard to mess it up. as for waking it, yea i did that. real simple too.
Not a 351M, but my 351C was still going strong after approx 235,000 miles without a rebuild (about half of which were on LPG) and several seizures sue to overheating (caused by dodgy radiator). I sold the car and now it's in an F-series truck and still running fine last time I heard.
