and quite well. i would say it is 75% new injectors/25% G codes but dam this truck is like a rocket now. i can pull hills doin 70 mph in 3rd with the rpms pegged around 3200 rpm. i was trying for more speed but i ran out of road before i could shift into 4th
it also feels a helluva lot better around town and will get up to 50 mph in to sweat.
Nobody said they wouldn't work, just that it isn't mandatory when putting on a turbo.
The finer atomization of the g and higher pop pressure makes a big difference. Sounds like you are happy and that is all that matters
so your running g code turbo injectors on a truck with no turbo? are you running the non turbo injection pump?. My truck is at the shop right now getting a new IP put on. they are going to turn up the pump for me and im going to replace the injectors myself on the weekend. your saying i can run g code injectors with the stock pump and it will make a difference?
If you have the pump replaced and then do the injectors later putting on the new injectors will change your timing and then you will need to take the truck back to the shop and have them retime it.
Would maybe bux ahead to just have them do it all at once unless you have a deal with them that they will retime it for free or something.
