Hello,
Anybody ever had their rear interior door panels come loose? It appears my little plastic barbed wedges are broke and the interior panel does not stay tight against the metal door. It is the right rear little 1/2 door, the one that you have to open 1st after the lift gate is up. I need to replace the plastic barbs I think.
Appreciate any info
Jeff
I don't think those barbs are replaceable You will probably have to go the nut and bolt route or another similar setup. Those barbs/connectors/whatever seem to be a "one time" use kinda thing. Pull it off once and it never seems to be the same afterward.
