Well, My GPR is slowly dying. Ive got a 2 volt drop on the output side and some white smoke for a few seconds in the morn. I found this as a replacement idea on the dieselstop forums:
"The 120-105711 is rated at 100 amps continuous and has silver alloy contacts. It's coil draws 6.6 watts or a little less than .5 amps. The price for one of these is $15.24 out of Grangers."
The .5 amp draw is what turns me on. Compared to the 4 amp draw on the Napa and OEM unit.
I installed the following Stancor/White-Rodgers Contactor, Power; Single; 200 A (Continuous); 12 VDC Mfr Part#:*586-902
Allied**Stk#:*576-1078 and it has worked flawlessly. Also, that's a good price. Good luck!
yep, I ordered the one Guzzle recommended, got it from the same place he did, and was about $55 shipped to me. got to install it this weekend if everything works out.
I installed one in my truck last fall and I'm glad I did week had several weeks this year of -0 temps for the high. Several days it got way below 0 like -25 the white rogers relay from guzzles write up, worked great.
