2bbl to 4bbl
Old Oct 3, 2001 | 08:35 AM
1ole4d's Avatar
1ole4d
2bbl to 4bbl
How would you change the teh 2bbl carb on the Modifed to a 4bbl? What 4bbl intake would fit on these motors? TIA
Robert
1978 F-150 4x4 Stepside 351M
Please don't pull out in front of me! The last thing I want to do is play identify the pieces with you or your car.
Old Oct 3, 2001 | 11:44 AM
bbtkd's Avatar
bbtkd
2bbl to 4bbl
[font size="1" color="#FF0000"]LAST EDITED ON 03-Oct-01 AT 12:47 PM (EST)[/font][p]
I would suggest the Edelbrock Performer 400, which also fits the 351M. I am partial to the Edelbrock carbs, but a Holley would work as well. A 600 CFM carb should be sufficient but note that you will need to have it jetted and adjusted. Plan on an open style air cleaner with a K&N filter. Also - since you are making it inhale better, plan on allowing it to exhale better - with at least dual exhaust and non-restrictive mufflers - and possibly headers. A cam always helps, and then....
Tom
Old Oct 3, 2001 | 11:49 AM
Chuck P.'s Avatar
Chuck P.
2bbl to 4bbl
Ran the Eldy performer(dual plane), worked ok for me. This is a 4V manifold. You can get an adapter to run your existing 2V for a while if need be (depending on funding-never seems to be enough!). I'm sure there is a few others such as Offy and Weiand to name two.
Old Oct 8, 2001 | 02:24 AM
fordmando's Avatar
fordmando
2bbl to 4bbl
They make a Non-EGR 4-bbl intake for M-blocks, as well as adaptor plates so any 351C intake will fit on a M-block. I think I'm going to switch from my current Performer (non-EGR, they make a EGR version)/Performer 600 intake/carb combo to a Weiand 8010 (I have heard them called both the Action Plus and the Stealth, so I don't know which on it actually is)/Speed Demon 650 or 750 combo.
fordmando
70 F-100 Ranger XLT 400 C6
78 F-150 4x4 400 4 on floor
George
Old Oct 8, 2001 | 02:06 PM
martinb's Avatar
martinb
2bbl to 4bbl
