1986 efi
Old Mar 10, 2008 | 03:56 AM
daboot's Avatar
daboot
1986 efi
I have a 86 5.0 efi runs good then takes a dump on and runs good a gain right now. after startup it will stay at high idle and while going down the road it feels as though the motor has killed until i get below 35 mph or put it in neutral it runs fine. I have a new ditrbutor and module. in park i can rev it all day. what could it be.
Old Mar 10, 2008 | 09:36 AM
Franklin2's Avatar
Franklin2
Read the codes and see what it has to say. Here's a site that tells you how to do it with a voltmeter or testlight.
www.fordfuelinjection.com
Old Mar 10, 2008 | 02:34 PM
rbaker6336's Avatar
rbaker6336
did you change fuel filter?
Old Mar 10, 2008 | 02:48 PM
Oscar Meier's Avatar
Oscar Meier
Check the fuel pressure - sounds like a clogged filter - low pressure to injector or clogged/dirty injectors
Old Mar 10, 2008 | 04:02 PM
blue beast's Avatar
blue beast
Gas line dryer triple dose or so don't do anything else just dump it in on whatever is in
the tank3/4 1/2 1/4 run it until 1/8 tank then refill with fresh fuel and some marvel
mystery oil and another bottle of iso heet. Unless that is too easy for ya.
Old Mar 11, 2008 | 12:20 AM
brthevio's Avatar
brthevio
Does the truck have dual tanks? If so there are actually 2 fuel filters on the truck. The usual one that is easy to find and see. The other is by the valve that swaps what tank you are using under the truck. It is on the drivers side on the frame rail. The filter is about $4. We chased a similar problem for weeks because we were unaware of this filter. Good luck, hope it is something simple.
Old Mar 11, 2008 | 09:50 AM
86stepsideF150's Avatar
86stepsideF150
Me too! I kept changing the easy to find fuel filter and it would clog back up again within a day. I actually changed the fuel tank, and still didn't fix it, until I finally found the stupid other fuel filter!
Old Mar 11, 2008 | 09:54 AM
rbaker6336's Avatar
rbaker6336
may '86 only had one filter,the one on the frame rail
Old Mar 13, 2008 | 10:20 AM
daboot's Avatar
daboot
Well the hesitation was to rhytmic to be anything but electical so i swap distributors and everythings decent. I do be leave i need a fuel pressure regualator.
