Engine stuttering??
Old Mar 9, 2008 | 09:45 PM
99EdeBauer's Avatar
99EdeBauer
Cool Engine stuttering??
My 99 EB with about 107000 on some start ups not all the time will idle real low and sound like it wants to stall. Hitting the gas makes the engine like putter then rev high. Like I said it does not happen all thetime any ideas?
Old Mar 10, 2008 | 12:47 AM
00FordLumberwagon's Avatar
00FordLumberwagon
I had this prob in my 00 is turned out to be the check valve in the fuel pump, is the check engine light on? and just like you said, it is only time to time......at first, like 2 days and goes away 3 months later it happens again........ for a day or too.... eventually it will do it all the time....I would suggest a fuel pressure gauge from autozone for 40 bucks, and when it is giving you a hard time throw it on there see if it gets 30-45 lbs at the rails....... then shut it off watch the gauge as it should hold pressure for at least 5 minutes....mine the needle dropped as soon as the key turned off......!
malodin
Jul 4, 2010 01:27 PM
rocco722003
25
Jul 17, 2008 06:28 PM
mike9254
1997 - 2003 F150
Apr 10, 2008 10:41 PM
bc56845
Dec 13, 2006 08:00 PM
