Door Panel
Old Mar 8, 2008 | 10:42 PM
Claydough's Avatar
Claydough
Door Panel
The lock on the front passenger side door has stopped working. Is there an easy way to take the door panel off so i can look and see what broke? Trying to fix the problem on my own.
Old Mar 9, 2008 | 12:41 AM
97 Mountain Man's Avatar
97 Mountain Man
What year?
Old Mar 9, 2008 | 05:04 PM
Claydough's Avatar
Claydough
1996. The passenger lock just makes a buzzing noise when I try and use the electric lock... it still locks manualy.
Old Mar 9, 2008 | 08:22 PM
CobraXP's Avatar
CobraXP
There are two screws below the door handle. Remove those, then remove the cover piece behind the handle. The rest of the panel is held on with about 8-12 push pins. If you have a pin tool to pry the panel out, that is the easiest. If not, use a flathead and start at the bottom of the door panel and find one of the pins. Then use another flathead to get on the other side of the pin and pull it out. Once you have one loose, you can get your hand in there to work your way around the rest of the panel pulling the pins loose.
You want to try and save the pins, but if you bend or break one, don't get too worried. A bag of 10 or so costs like $3.00 from Ford...
Old Mar 10, 2008 | 01:05 AM
Claydough's Avatar
Claydough
Thanks for the info.
Old Mar 11, 2008 | 02:56 AM
460's Avatar
460
The pins are also available at AutoZone and similar places... just in case the Ford dealer is closed when you do it.
