high idle
The adjusting bolt is under the factory black roundish cover on top of the throttle body "4X2Mudder shows" you may be able to "knock it down" with the adjusting bolt .........
But if the idle was normal before, then you are just covering up a problem, not fixing it, by turning this bolt out.
Plug off the vacuum line to the PCV valve with your thumb/Vacuum cap/ or a big bolt.
It should drop your idle WithOut adjusting the screw. And it should run smoother with the line plugged. This would tell you your getting an internal leak comming through the crank case via the PCV.
This is why it's better to buy the more expensive PCV's in my opinion.(if you use them)
But Seeing how the PCV dose not "help" the engines preformance at all, and is just an emmissions part.
I can tell you how to fix it and not ever worry with it again......
Pull the the hose off the back of the metal elbow on the back of the intake.
Unscrew it out of the intake and take it with you to Home Depot.
Go to the plumbing section where the brass fittings and connectors are.
You will need to match the threads to a short Double Male Fitting (@ 3/4 " of threads on both sides) then you will need a brass cap for it, and some high temp. teflon tape.
Tape the threads and bolt on the cap to the double male fitting, then add some more tape to the other threads and screw it in to the back of the intake. I did mine 5+ years ago, never worried with it again.
Now buy 3' or so, of vacuum hose to fit the PCV valve.
Put the hose on the PCV. Then replace the PVC back in the valve cover.
(givin room for slack/ slight curve will do ) run the hose over to the plastic inner fender well, down to the side of the frame , and hold the hose in place with zip-ties attached around the hose and through some of the existing small holes in the frame and plastic inner fender. Once they are fastened tightly enough. Trim the hose to the bottom of the frame leaving about 2-3" under hanging.
The PCV will still breath this way and you wont get any moisture in the covers from an open hole of no PCV there.
You may see a puff of light smoke occasionally at the stop light when the crankcase "burps" itself . Normally this would be sucked back in to the intake .
And you wont have any more future problems with a possible air leak comming from the crankcase via the PCV. I did mine 5+ years ago and have never had another problem there again.
Get this............Some people run the cover hose (PCV) up to holes in there hoods. The hoods will have a small fake scoop(s) and the light burp of the smoke makes the hood scoops look like they are "breathing" slightly.
The smoke is just the mynute amount of combustion gas that slips past the piston rings into the crank case. It's just a light thin single blow off ,puff that will bleed out , as your sitting at a stop.
It gets there from the prior engine rpms , it's hardly noticable most of the time.
This is just a neat way to fix a problem , and change it to some style at the same time with no harm to anything.
I would not adjust the idle by the bolt untill I went over all the other hoses and lines first ( in fact the little black and yellow factory sticker on the side of theT.V.Bores tell you not to adjust the bolt .......But....)
Just snip back a section of the vacuum hose ends and replug the connections.
I have done plenty of modifications to my 1991 - 5.0 (pictures in profile), And it is now 1 hassle free truck, spacious and easy to work on when needed,
I even got rid of the A/C , (we have vent windows and sliding back glass), but the a/c radiator condensor (in front of the radiator ) is soon to be a super effecent transmission fluid cooler.
And look closly at the right side of the throttle valve , theres 2 vacuum line plugged there (1 on top of the other) that tend to be well hidden places of those sneaky leaks that develop over time.
If the idle speed doesn't change when you disconnect the air bypass valve, you probably have a vacuum leak. Vacuum leaks can come from the uppper or lower intake gaskets, broken vacuum lines, injector o-rings, or from a bad brake booster. Carefully use a can of brake or carb cleaner and spray around all of the intake gaskets. If the engine speeds up, check for bad gaskets. Also, disconnect the vacuum line to the brake booster and plug it. If the idle comes down to normal, the booster is bad. Also, verify you have the correct PCV valve, as they have different flow rates. For the two or three dollars they cost, replace it if you haven't already.
I had the same problem on my 90' f150. The engine just started to run at high idle all time. Checking for vaccum leaks etc.. I found out that the intake plenium gasket was leaking/blown. Once I got a new gasket installed the leak/high idle problem was fixed and it runs fine now. Good luck!
