Sponsored by: Innova
Help me complete my system
Old Mar 8, 2008 | 07:45 PM
jnowlin's Avatar
jnowlin
I've been out of the car audio scene for a long time and don't know what would be the best setup for my 2007 Supercrew. I don't need the loudest brain-rattling system possible, but I would like some good clean sound. With this in mind, I have already purchased the following amp and subwoofer enclosure:
Alpine MRP-M45 amp
mono subwoofer car amplifier
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
variable low-pass filter (50-200 Hz, 24 dB/octave)
tuned Bass EQ (0-12 dB bass boost at 50 Hz)
subsonic filter (15 Hz, 24 dB/octave)
MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
gold-plated screw terminals
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
9-3/4"W x 2-3/8"H x 9-9/16"D
JL Audio Stealthbox
ported fiberglass enclosure
10", 2-ohm DVC W3v2 subwoofer wired for 4-ohm mono
fits under the rear bench seat
power handling: 100-300 watts RMS (600 watts peak power)
What would you guys suggest to finish out the system? I have seen rave reviews of Alpine Type R's on here, but I don't know which ones people are using. Or are there better options out there that are not too high dollar? I realize I'll need any amp for the highs. I currently have an old Pioneer GM-840 that is 35W x 4 as well as an old Rockford Fosgate Punch 75, but I don't know if either of these amps are good enough to use in this application. If not, what would you suggest?
For the front doors, I had thought about getting some good components powered by the appropriate amp. For the rear doors, I had thought about just continuing to use the factory speakers powered off of the factory head unit but with some sort of crossover to keep bass out of these speakers. The reason I was considering this is that from what I have read, you just need a little for rear fill and don't want it to be too overpowering. In addition, it would let me purchase a cheaper two channel amp, if I need to buy one, and my fade would still work. What do you guys think about that setup? Your suggestions are greatly appreciated.
Old Mar 12, 2008 | 10:38 AM
rotun's Avatar
rotun
Reads ***** rules!
MB Quart mids in the doors, components in kick panels from Q-logic. Definately use dynamat or? in the doors. Check my gallery, this was setup for sound quality (sq) as opposed to sound pressure (sp).
Old Mar 12, 2008 | 07:51 PM
XolieX's Avatar
XolieX
hey homie i spoke with you before! do you want to know how to finish off your system off with a ton of cash or moderate cash?
well if you don't have a ton of cash like most people this is what i'd go with.
definitely go with component speakers in the front, most of your money should be spent there! don't ever skimp out on the front speakers! i bought some polk audio db 5.25 component they sound great and the mid bass is great with them. however most people go with the 5x7 conponents which sound great too. i'd recommend the infiniti reference components for this set up. they are alumium dome but they aren't that harsh like most alumium tweeters.
for the rear, just get any plain jane 5x7 because they are just the rear speakers. i'm sure any 60 to 70 dollars 5x7 would do just fine! hell, polk audio db's are selling for 50 dollars from crutchfield. i think they are still offering buy a pair of speakers get the other 1/2 off.
once you figure out what speakers you want, you should get an appropriate amp for them. try to at least give them 80% of the power they are rated for or at least 70%. don't worry about the rear rating because you should set those just to fill up the sound and not neccesarily equal to the fronts! its ok to go with 70rms to the rears when they are only like 50rms because they shouldn't be set that high compared to the front.
if your going to power the front door speakers with an amp, don't run the rears off the deck. because you will have adjustability on tune with the front and absolutely nothing with the rear. you should have adjustability with all 4 speakers. your best bet is to absolutely feed them off of a 4 channel.
Old Mar 12, 2008 | 07:52 PM
FoundOnRoad's Avatar
FoundOnRoad
After extensive research I decided to go with Phoenix Gold RSD6CS (6" components for my front stage and I went with MBQuart DKF 168 6x8 coaxs for the rear fill. The PG's were highly rated by the users on DIY Mobile Audio forum as a decent inexpensive (around $90.00 shipped) components. They are rated at 60 WRMS but are said to take double that with no problems. I'm giving them 75 WRMS from my JL 300.4 with no probs and I think they sound great. But remember speakers are a very subjective matter and what sounds good to me may sound like crap to you. I also deadened and sealed my doors with RAAMmat and Ensolite which helped tremendously. You should at least put some acoustical foam behind the speakers. I have read that those camping mats sold at Wallyworld are inexpensive and work well.
Old Mar 12, 2008 | 09:58 PM
jnowlin's Avatar
jnowlin
Thanks for the replies, guys. It is much appreciated. XolieX, you are the second person to recommend Infinity speakers. The other person who recommended them said that the Kappa 60.7CS components would work really well with the Punch 75 that I have now because they have a sensitivity rating of 95 dB. Do you agree? Of course, like FoundOnRoad said, everyone has their own opinion. One guy on another forum absolutely hates Infinity speakers.
Old Mar 12, 2008 | 10:20 PM
rotun's Avatar
rotun
Reads ***** rules!
It wasn't me in the other forum but I hated them as well and replaced with the MB's. I gave the Infinity Kappas to my brother and they sound way better in his truck then they did in mine. Same speakers, different model vehicles....which is absolutely a factor that needs to be considered when setting up a sound system. Ask others that have same vehicle as you if you could hear what they have and go from there.
Old Mar 13, 2008 | 12:50 AM
XolieX's Avatar
XolieX
jn, i believe you got a f150 like i do. i believen round speakers thas why i didn't go with the 5x7 components. however people go with them because they want more mid bass which the 5x7 will generally produce more than a 5.25. my 5.25 puts out great mid bass however.
this is what i recommend. try a 5.25 round component, possibly the pol audio db's like mine for 180 and then get a 5x7 for the rear and its 1/2 off. if you don't like them, and you buy from CRUTCHFIELD.COM they will take it back and sell you another pair. the ones i got are silk dome, at loud volume they are not harsh on your ears and its smooth. however, if you don't like the silk tweeters, go with an alumium dome tweeters like the infiniti, however get the REFERENCE series but they are better than kappa i beleive. if you dont like the mid bass from a 5.25 then go with the 5x7 components.
all in all though dude, SPEND MOST OF YOUR MONEY IN THE FRONT DOOR SPEAKERS! YOU CANT GO WRONG WITH THAT! DONT SKIMP OUT TO GET BETTER REAR SPEAKERS. I'D RATHER SPEND 200 ON THE FRONT SPEAKERS, AND 50 ON THE REAR THAN SPEND 125 ON EACH SET OF SPEAKERS!
if you go to crutchfield, they have sales all the time, buy a set of componenets from them with pol audio its 180 for the components, and the 5x7's are 1/2 off for 30 bucks. thats 210 for speakers and you'll be happyl.
you can pm me if you'd like dude!
Old Mar 16, 2008 | 03:10 PM
FoundOnRoad
The fact is, you will always get better midbass from a round speaker. That's why I went with a 6 in. round component set. All I had to do was make a 5x7 / 6x8 adapter from MDF to mount the round midbass into, and then trim a small amount from the speaker basket to get it to fit into the stock location in my 07 F150 Screw's door panel. I mounted the tweeter into the factory hole for stealth purposes, and mounted the crossovers into the bottom of the map pockets on each door (inside the truck).
Old Mar 20, 2008 | 09:00 PM
XolieX's Avatar
XolieX
amen, round speakers rule!
