Sound Deadener?
Old Mar 8, 2008 | 12:22 PM
TchTchr's Avatar
TchTchr
Sound Deadener?
Has anyone installed a sound deadener mat (i.e. Dynamat) under the hood? We had six inches of snow last night and man was that engine quiet this morning!
Thanks
Old Mar 8, 2008 | 12:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
No, but it wouldn't be hard. I used B-quiet ultimate inside my cab, and that stuff is heavy. I want to put some on the firewall too when the engine comes out. But, putting it on the hood wouldnt be hard, its like stick on chrome LOL..
I'd put it on mine if the bottom of my hood wasnt so cool looking.
Old Mar 8, 2008 | 12:59 PM
F250_'s Avatar
F250_
If you add much weight to the hood, though, be prepared to also increase the load rating on the hood lift cylinders. At 29 degrees this morning here in Birmingham, the stock lift pistons wouldn't even hold my hood up. Every time I walked away from it to get something from the garage, I would hear the SLAM after only 5-10 seconds from letting go of it.
Old Mar 8, 2008 | 01:16 PM
PaysonPSD's Avatar
PaysonPSD
Your next Mod could be "custom 1 inch cut to length pvc pipe hood prop".
It will be called the "Petedad". At least your hood had the good manners not to drop on your head. My hood is not so mannerly.
Old Mar 8, 2008 | 01:27 PM
PowerstrokeJunkie
Or do it like BWD and use a 2x4 LMAO
Old Mar 8, 2008 | 01:34 PM
F250_'s Avatar
F250_
Before I can use a name like the Petedad, in honor of a previous member who sold out to get a Cat, I would first have to be able to generate all the tabulated possible forces dependant on wind direction, ambient temperature, and pipe gauge...
Old Mar 8, 2008 | 01:52 PM
TchTchr's Avatar
TchTchr
Mmmmmm . . . hood shock mod in the works?
Can't till spring!
Old Mar 8, 2008 | 05:59 PM
PaysonPSD's Avatar
PaysonPSD
ROTFL Too funny Pete.
I think it would be less painful to get head in the head with the hood than read through the analysis.
Old Mar 8, 2008 | 08:08 PM
F350-6's Avatar
F350-6
I'm undecided. Someone post a graph that I don't understand and I'll make my decision.
Old Mar 8, 2008 | 11:08 PM
F250_'s Avatar
F250_
Here ya go, Chris... is this what you were looking for??
Old Mar 8, 2008 | 11:13 PM
F350-6's Avatar
F350-6
Thank you. After careful review of said graph I have determined you need a wooden broom handle cut to length to prevent the onset of sudden headaches.
Old Mar 9, 2008 | 08:38 AM
RogueSpear2023's Avatar
RogueSpear2023
I think your cylinders may need to be replaced mine work great even when it is -25 outside And yes it gets that cold here even colder sometimes.
Old Mar 9, 2008 | 02:21 PM
F250_'s Avatar
F250_
Originally Posted by RogueSpear2023
I think your cylinders may need to be replaced mine work great even when it is -25 outside ...
You're probably right. I'll have to check into my options....
EDIT:
I checked and for some strange reason, the two cylinders are not priced the same. Check it out. The screen shot is straight off of DirectFordParts' web site.
Old Mar 9, 2008 | 03:11 PM
PowerstrokeJunkie
But they are both the same thing. Should be interchangable?
Old Mar 9, 2008 | 04:06 PM
F250_'s Avatar
F250_
That's what I was thinking, too, Kris. I'm going to call on it tomorrow if I can get a few free minutes.
