General Automotive Discussion
need help bad please!!!!! gauges.....
Old Mar 7, 2008 | 08:29 PM
CKBLOOD05's Avatar
CKBLOOD05
ok i bought some nu-image white gauges with red flames for the ac/heat controls and the main gauges for your speedo,tach,etc... well after taking everything all aprt that needed to be removed,i got to the gauge cluster.i removed the clear plastic that cover the cluster.next i removed all the needles on all the gauges.but..... i forgot to make a sketch of where all the gauges were pointing.the directions said to start the vehicle rev it up a couple of times the let it idle.then to make a sketch of your gauges on paper.but i just went ahead and pulled all the needles. i just filled my tank,so i know where the needle for that is pretty good.i know with the [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]truck[/font][/font] running at idle the speedometer would be at 0.it idles around 750-800 rpm's when warm.my thermostat is about half way just a little tad under when warm.my oil pressure is about at the half way point.and my battery needle is around the half way point.how do i go about getting all the needles where thay need to be????? any help please! thanks a million.
Old Mar 8, 2008 | 01:31 AM
Mil1ion's Avatar
Mil1ion
what truck is this ?
Old Mar 8, 2008 | 02:36 PM
CKBLOOD05's Avatar
CKBLOOD05
its a 2000 explorer sport with the 4.0l ohv.
