460 swap
Old Mar 7, 2008 | 06:50 PM
1awesomehighboy's Avatar
1awesomehighboy
highboy question #1
hey im new to all this and dont want to step on anyones toes so give me some time to get the hang of this. i know this topic has been covered several times on here but cant quite find the right info i need at the moment. i have a 70 f250 4x4 that came with a 360 np 435 and pretty sure a divorced 205. (correct me if im wrong) i have a built 460 sitting in my shop and all i lack is headers carb and dist. my problem is so many options i dont know what is the best way to go so any help would be appreciated
Old Mar 7, 2008 | 09:22 PM
1awesomehighboy
460 oil pan
the 460 i am putting in my 70 highboy has a front sump pan will it clear my front crossmember. the guys at l and l say it will just wondering if anyone had any input
Old Mar 7, 2008 | 09:46 PM
wizzard351's Avatar
wizzard351
when i had a 429 in my old hi boy i used the front sump pan and never hit it
Old Mar 7, 2008 | 09:50 PM
1awesomehighboy
thanks i figured it would be ok just wanted to be sure i have ran into so many issues one this project should have stuck with the 360. would you know the best place to get headers without breaking the bank
Old Mar 7, 2008 | 09:54 PM
wizzard351's Avatar
wizzard351
any swap headers are goin to be pricey i just used some cj mustang manifolds and notched the frame a tad
Old Mar 7, 2008 | 09:56 PM
1awesomehighboy
would really like help on the headers what year truck do i need to buy for would the headers of a 74 -77 highboy work
Old Mar 7, 2008 | 09:58 PM
1awesomehighboy
yea those fender exit headers are nice but high i was wondering if some like 73 75 year model headers would work i can get some for like 200 dollars
Old Mar 8, 2008 | 09:33 AM
TigerDan's Avatar
TigerDan
Hi and Welcome!
I just swapped a 460 into a '72. It's a 4X2 that I converted to 4X4 so the motor mount/perch situation is a little different than what you would experience. The headers I used were some that were donated to the cause by another member. I believe they were indeed for a later 460 truck and were a perfect fit.
Here's a page from Summit that has headers that should fit this application. All pretty pricey, but with some research you should be able to get the price down:
http://store.summitracing.com/egnsea...=KeywordSearch
Also, be sure to check out FTE's classifieds as there may possibly be a member selling a used set...
And I have combined your two threads on the subject to make it a little easier to keep track of the info.
Old Mar 8, 2008 | 11:29 AM
LuckyLuke's Avatar
LuckyLuke
I did the exact same that you are doing and after buying three different styles of headers I found some L&L shorty headers on http://broncograveyard.com/ for $450.00 They are really nice. The flange is 1/2 inch thick! I liked the fender well style headers but my steering ended up being in the way.
Old Mar 8, 2008 | 11:39 AM
LuckyLuke's Avatar
LuckyLuke
Here is a link to the ones I purchased. http://broncograveyard.com/bronco/i-...7-79_f250_.htm
Old Mar 9, 2008 | 03:53 PM
1awesomehighboy
thanks for all the help guys this place is a whole lot better than some of those other sites maybe its just the chevy guys. but sice the 460 never came in a 4wd drive in the 70s would the headers for a 4x2 work
