1978 - 1996 Big Bronco
Squealin tensioner
Old Mar 7, 2008 | 06:28 PM
wetneck's Avatar
wetneck
Squealin tensioner
so I's pull my tensioner this evenin and in my hurry i didnt look to see if the spring went INside the base mount or around it....when i tighten the new one down, the spring holds up against the curved upper base part on block, not allowing tensioner to seat...... if i KNEW i could just swap the pulley from new to old TENSIONER , ida done that in a jiffy....so... is there an easy way to align the spring ?? i gave up after dark when i had to hold a flashlightin my teeth....
Old Mar 7, 2008 | 08:29 PM
blue beast's Avatar
blue beast
What year and motor? I am pretty sure it goes inside if I am thinking what you
have by telepathetic means!!
Old Mar 7, 2008 | 08:33 PM
wetneck's Avatar
wetneck
Old Mar 8, 2008 | 01:36 PM
wetneck's Avatar
wetneck
well....go er figgered out....spring goes on the outside, no room inside..but what a pain ....had to use vise grips and a monkey wrench to align spring, then was cake.
