snow plow?
Old Mar 7, 2008 | 05:45 PM
wizzard351's Avatar
wizzard351
snow plow?
does anyone have a plow on a f150? i need to find out how far off the ground the lower mount is. i got a freebie plow but its off a jeep and i have to make a lower braket. even some pics of the plow mount would be nice. the one i got is a old meyers(i know they junk but it was free) that the mount stays on year round
Old Mar 8, 2008 | 01:06 PM
waynaferd's Avatar
waynaferd
I got a Fisher Minute mount so that won't help.
I'm about to put a 4" lift in mine and 35's, but I'm just weld a piece of steel to where the plow actually hooks to the head gear so it'll be lower to the ground. That's where I'd do my adjusting at, and keep the head gear up higher and out of the mud.
Old Mar 9, 2008 | 10:24 AM
lostin90s's Avatar
lostin90s
About 6"-8 is the average Of all Plow (and I have a 1 ton now) I have had you can go higher. Dont forget to throw some F350 844s Coils in front you'll thank me.
Old Mar 9, 2008 | 11:48 AM
JasonJ1969's Avatar
JasonJ1969
You need to make sure that the assembly that goes from the blade to the mount is level when the blade is down. Otherwise, if the assembly is angled up from the blade to the truck, the force of pushing snow will be unweighting the front end, and you lose some of your traction, and even steering if it is bad enough. Also, the blade won't cut like it should. I have plowed commercially for 9 years and set up several trucks. Just look at any pro install. In fact, you should try to find some examples of your blade on your style truck, and mimic the mount or even just buy the proper mount and save yourself the headache of trying to fabricate one (unless you are a master welder). You can't just weld up any old thing and stick it on, the frame WILL bend unless the right geometry is involved. This year I had one guy tear off a BOSS V blade mount on a 95 F350, and that was a proper professional mount. Granted, if you are just doing your driveway, you might not see the abuse our rigs do, but you still want a strong setup or your frame will get bent. Especially on an F150. I tore out the frame horns on a Chevy 1 ton this winter and had to reweld the whole mess, and the accounts that truck sees are all easy little driveways. All it takes is one good hit on a frozen pile....
Old Mar 9, 2008 | 12:57 PM
wizzard351's Avatar
wizzard351
i dont think they ever put a permenent plow mount on a truck this new so i doubt i could buy the rite braket but i do have good fab skills so it shouldnt be a problem. i gess ill have to put the blade infront of it on a block so its level and biuld from there
Old Mar 9, 2008 | 03:59 PM
tjc transport's Avatar
tjc transport
i ain't rite
what year truck are you talking about?? if you are refering to your 92 F150, the mounts are readly available from myers.
here are the part numbers for the meyers parts.
PARTS & INSTALLATION INSTRUCTIONS
MEYER SNOW PLOW MOUNTING
1984 & Later FORD BRONCO,
F150, F250, F350 4x4 VEHICLES
IMPORTANT NOTICE
End user must be given this instruction sheet prior to delivery of this Snow Plow.
The equipment you have just purchased should only be used on vehicles equipped with the Manufacturer’s Snow Plow Preparation Packages.
Snow Plowing without the original Snow Plow Preparation Package may damage your vehicle and the added weight to the equipment may
impair the operation and control of the vehicle . Snow Plowing with a vehicle that the manufacturer does not recommend for that purpose may
void your new vehicle warranty. If your vehicle is not originally equipped with the Snow Plow Package, additional parts may be necessary before
snow plowing. Owners of these vehicles should consult their dealers before purchase or installation of such parts. CAUTION: the installation, on
any vehicle , of these parts is not a full substitute for the original equipment Snow Plow Preparation Package.
Warning: Lift Arm extends beyond bumper of vehicle. To minimize damage from a front-end collision, Lift Arm should be removed from
vehicle when Snow Plow is removed.
PARTS LIST
© 2003 Printed in the U.S.A. 18513 Euclid Ave. • Cleveland, Ohio 44112-1084
Phone 486-1313 (Area Code 216)
email warranty@meyerproducts.com
Meyer Products reserves the right, under its continuing product improvement program, to change construction or design details,
specifications and prices without notice or without incurring any obligation.
Parts indented are included in the carton, bag or assembly under which they are indented.
ITEM PART NO. QTY. DESCRIPTION
17081 1
MOUNTING CARTON
1 11007 1 • Lift Frame
2 11235 1 • Side Member, LH (Replaces 10777)
3 11234 1 • Side Member, RH (Replaces 10778)
4 10773 1 • Clevis Frame
5 10514 1 • Lift Arm
6 10774 2 • Strap
7 11013 4 • Bumper Brackets (’84 - ’86)
8 11180 1 • Trim Clip, R.H . (’87 & Later)
9 11181 1 • Trim Clip, L.H . (’87 & Later)
10 11182 2 • Trim Piece (’87 & Later)
08560 1
• Hardware Bag
11 22086 4 •• Bolt, 1/4-20 x 1 “(Black)
12 20066 8 •• Bolt H 3/8-16 x 1-1/4" Gr . 5
13 20140 2 •• Bolt H 5/8-11 x 1-3/4" Gr . 5
14 20141 8 •• Bolt H 5/8-11 x2" Gr . 5
15 20144 1 •• Bolt H 5/8-11 x 2-3/4" Gr. 5
16 20147 2 •• Bolt H 5/8-11 x 3-1/2" Gr. 5
17 20164 2 •• Bolt H 3/4-10 x 2" Gr. 5
18 20166 2 •• Bolt H 3/4-10 x 2-1/2" Gr. 5
19 14595 2 •• Special Bolt, 3/4"
20 20351 2 •• Flatwasher 1/4"
21 20357 10 •• Flatwasher 5/8"
22 20303 4 •• Locknut 1/4-20
23 20305 8 •• Locknut 3/8-16
24 20309 13 •• Locknut 5/8-11
25 20310 6 •• Locknut 3/4-10
26 22099 2 •• Locknut 12mm x 1 .75p
27 10797 1 •• Spacer
11“ Sector 15” Sector
Part No. Qty. Part No Qty. Description
16288 1 06249 1
Sector &A-Frame Carton
12326 1 12793 1 • Sector
13306 1 13319 1 • A-Frame
07017 3 07017 4 • Trip Spring
08166 1 08341 1
• Plow Hardware Bag
09119 2 09119 2 •• Pivot Pin w/Cotter Pin
11101 2 11101 2 •• Hinge Pin
22083 2 22083 2 •• Linch Pin
09122 1 09125 1 •• King Bolt w/Locknut
09124 3 09124 4 •• Eye Bolt w/Locknut
09916 1 09916 1
•• Plow Marker Kit
08201 2 08201 2 ••• Plow Marker Assembly
12816 2 12816 2 ••• Clamp
20005 2 20005 2 ••• Bolt H 1/4-20 z GR. 2
20312 2 20312 2 ••• Locknut 1/4-
NewfieEd
Nov 1, 2015 06:42 AM
Plumberdude3
Apr 4, 2015 05:54 AM
JD_F250
Dec 1, 2010 08:54 PM
JD_F250
19
Dec 10, 2009 02:25 PM
firefytr29wfd
Jul 2, 2007 10:22 PM
