generator not charging
Old Mar 15, 2008 | 12:10 PM
matt2491's Avatar
matt2491
One day my truck wouldn't start, because the battery was completely dead. I charged the battery and let it sit. A day later I tested it and found it wasn't the battery. Therefore, I then suspected the generator. I pulled it out and took it over to my local AdvanceAuto where they have a test station for starter motors and gen/alternators. Hooked it up, no juice. Bought a new 65 amp alternator right there and proceeded to install it in the truck. I then realized that the regulator I had wasn't correct, so I went back to the store and decided I could make do with a '65 F100 voltage regulator; they didn't have one for '64. I mounted it on the inner fender and figured out all the wiring. Patience was KEY here for proper installation; take your time to figure out how to wire everything CORRECTLY. Once I had it all wired up, I fired it up, and after a couple days, it was charging my battery and starting better than before!
Old Mar 15, 2008 | 03:32 PM
norwood312's Avatar
norwood312
All the wires look fine. My alt light comes on and wont go off. Could it be another fuse?
Old Apr 10, 2008 | 03:11 PM
ihateminimumwage's Avatar
ihateminimumwage
Matt2491:
I know this thread has been dead for a month, but I was wondering if you had any shots of the crankshaft pulley on your motor. I'm looking to do the exact conversion you have pictures up of, on a 390, but I'm not sure if the stock pulley will line up when I install the alternator.
Old Apr 10, 2008 | 05:00 PM
matt2491's Avatar
matt2491
You know that I have a 292 right? I don't know what you are thinking about doing, or even if the engines are similar...
Tomorrow I'll go out and snap a pic of the belt setup.
Old Apr 10, 2008 | 05:03 PM
ihateminimumwage
I know they're completely different, but the generator mounts are similar, and I'm just trying to get a base idea of the conversion without buying an overpriced kit.
Old Apr 10, 2008 | 09:22 PM
matt2491's Avatar
matt2491
Okay here are some pictures; I'm not exactly sure what you're looking for, but as requested:
Nice and big pics for ya! Hope they help.
Old Apr 10, 2008 | 10:16 PM
ihateminimumwage
Thanks a ton. I think I can get my alt to line up if I replace the pulley on the crankshaft or the alternator pulley. Thanks again!
Old Apr 11, 2008 | 12:14 PM
billy12360's Avatar
billy12360
sorry for the thread high jack... but... are those reds headers???
Old Apr 11, 2008 | 02:48 PM
airharley's Avatar
airharley
Hey Matt can you rotate your lower radiator hose worm gear clamp on the water pump away from the water pump pulley. I'd hate to hear that your truck died on you when the belt broke. The fan belts actually flare out when they are spinning pretty fast. Just a little worldly advise for one of those been there done that guys.
Old Apr 11, 2008 | 04:55 PM
matt2491's Avatar
matt2491
Thanks for the tip airharley! That's what we're all here for.
Well, I didn't buy them specifically from Reds Headers, but yes they are those headers you're talking about. As far as I know, some manufacturer somewhere makes these headers, but a whole bunch of distributors sell them...
Let me tell you, these headers are a huge improvement over the original setup... I think they also have shorty headers, in case you want to route your own exhaust wherever you like. The full-length headers above go under the crossmember supporting the bellhousing.
Here's a couple pics showing the headers and where they dump:
Old Apr 19, 2008 | 12:12 PM
tx64f100tx's Avatar
tx64f100tx
does any one know how much of a spacer is needed for all of the brackets to do the alt to gen conversion?
Old Apr 19, 2008 | 03:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
GOOD THING, IT WOULD HAVE BEEN WRONG.
Prior to 1965, generators were standard equipment on all Fords except one, so if you get a voltage regulator for a 1964 F100/350, it would have been for a generator (C3TZ-10505-B).
1963/64: The Thunderbirds only came with alternators.
The alternator regulators are the same from 1965 thru 1988, car & truck ('63/64 T-B).
The alternators are the same 1965 thru 1979 ('63/64 T-B).
There are several different amp alternators available. The cars use the exact same ones.
Old Apr 19, 2008 | 06:12 PM
  #28
matt2491's Avatar
matt2491
Yeah I already knew that. I already had a voltage regulator for generators sitting here, so I did know that I would've needed the alternator-type anyways.
Thanks.
Old Apr 21, 2008 | 11:42 AM
  #29
tx64f100tx's Avatar
tx64f100tx
So for the conversion i have to get a 65 voltage regulator instead of a 64?
also when i hooked my altenator up, my gen light on my gauge cluster stays on even when the key is not in the ignition, can someone tell me which wire this might be?
Old Apr 21, 2008 | 12:24 PM
  #30
matt2491's Avatar
matt2491
tx64f100tx, PM sent.
Hanger53
Oct 19, 2016 07:07 PM
Gordesky Mco
Bronco II
May 7, 2016 12:23 PM
F250Rob
20
Feb 18, 2016 08:05 PM
19fifty4
Jul 4, 2012 12:59 PM
Rusty_S
General Automotive Discussion
19
Jan 4, 2010 09:26 AM
